Detect invalid handles
KN_Michael
Background
We do push handles and some data into a tree structure and do use those handles quite often for some calculations and updates. This happens inside the idle event. The problem is, that FAST undo/redos SOMETIMES (its very hard to replicate) lead to handles being invalid in the sense of that the handle is not a null pointer but accessing the handle crashes the application with an invalid access exception.
This tree data is cleaned and recreated on each file change/open so we only hold handles of the current active document inside the tree.
Is there a way to validate if a handle is valid? I'd need something like following:
bool valid = handle != NULL && gSDK->IsValidHandle(handle)
But the second part does not exist... Any ideas how to solve this?
Edited by KN_Michael
I do not know a definitive answer to this. We do have our problems with invalid handles at times too.
You can check not only that the handle is a nullptr but its dereference (*handle) too. However that is not enough either.
The next step is to check its the parent layer return for that object. The layer and its parent should not be null. (Not sure if this is valid for symbols, because in in our code, why have extra code for symbols too.)
This does work for me, but I'm not 100% sure it's the best way to go...
		// Create an object and delete it.
		MCObjectHandle locus = gSDK->CreateLocus( WorldPt( 0, 0 ) );
		gSDK->DeleteObject( locus );
		// Check if object still exists in the drawing.
		VWObject obj( locus );
		if ( obj.GetType() == 0 )
			// Object does not exist in the drawing anymore.
I discovered that handles need to always be initialized if not immediately assigned to a return value.
For example:
MCObjectHandle hObject;
Will not evaluate to null, nullptr, or false. You have to use:
MCObjectHandle hObject = nullptr;
or the equivalent class initialization.
This may be obvious to most, but until I realized this, some null checks were failing.
Scary.  Do you know if this is true in the VS environment.  I check for NIL handles, but have never initialized any.  From what you wrote, it would seem a collection of:
HandleVar := NIL;
statements would be required at the beginning of every script command or contained in any initialization subroutine.
I don't thinkg so, I have the feeling this is dealt with by the VS API, all these scripts messages 0.
PROCEDURE Test;
VAR
	h : HANDLE;
BEGIN
	Message(h);
END;
Run(Test);
PROCEDURE Test;
	PROCEDURE Proc;
	VAR
		h : HANDLE;
	BEGIN
		Message(h);
	END;
BEGIN
	Proc;
END;
Run(Test);
PROCEDURE Test;
VAR
	b : BOOLEAN;
	FUNCTION Func : BOOLEAN;
	VAR
		h : HANDLE;
	BEGIN
		Message(h);
		Func := false;
	END;
BEGIN
	b := Func;
END;
Run(Test);
  • 2 months later...
