I am in VW2022 + when I add a 3D object to a Slab the concrete texture is replaced with a weird kind of gradient texture + nothing I do will bring the concrete texture back:
Until I delete the modifier:
If I export the file to VW2021 all is fine:
Before running the command:
After:
Anyone else noticed Add 3D Object to Slab behaving strangely in VW2022? @Matt Panzer could you look at the file for me? It's strange because in a blank VW2022 file I can get it to work so I assumed it was something particular to the project file that was causing it, but then when the project file is exported to VW2021 it works which suggests it's a VW2022 issue...
Thanks
Edit: Ok if I export the file to VW2021, perform the Add 3D Object to Slab operation there, then open the file back up again in VW2022 the concrete texture remains in place. Unless I enter the edit mode for the modifiers + exit again: then the concrete texture is replaced with the grey gradient once more
Tom W.
After:
Thanks
Edited by Tom W.Link to comment
13 answers to this question
