hollister design Studio Posted October 27, 2021 Share Posted October 27, 2021 Issue with z value. VW2022 - once a plant object has been sent to surface, the z value in the OIP does nothing. It stays at 0 and changing has no effect on the relative Z Here I've sent to surface - and then changed the Z to 2' - no effect VW2021 - after you've sent a plant object to the site model surface, you can adjust the plant object with the z-value in the OIP Here I've sent to surface - and then changed the Z to 2' - the plant object is now 2' higher than the site model as expected. Also: it would be great is "send to surface" was a toggle on the OIP! Also 2: Other objects seem to keep relative z value after they have been sent to surface. For example -a test object at 0 is sent to surface. Now it's Z value is 2'3.74" If I adjust the z back to 0 it goes to zero. If i send it back to surface it goes back to 2'3.74" 3 Quote Link to comment
0 Nico_be Posted November 17, 2021 Share Posted November 17, 2021 I have the same problem. I've created a ticket to support. 2 Quote Link to comment
0 Vectorworks, Inc Employee bozho Posted November 24, 2021 Vectorworks, Inc Employee Share Posted November 24, 2021 @hollister design Studio @Nico_be Thank you for reporting this issue. The fix of it will be included in the SP3 release. 2 Quote Link to comment
0 hollister design Studio Posted December 16, 2021 Author Share Posted December 16, 2021 @bozho Stange thing just happened... I've been working on a file today and the Z values were working as they were supposed to (plants in planter boxes with a Z value of 24" where 24" above the site model and showing well in the planter box). And then I accidentally moved my Plant layer elevation up from 0" to 24" and all the custom Z values stopped working. When I returned the Plant layer to 0" the z values did not restart. No matter what I do now (even ctrl-Z back the before the change) I can't get back to Z value working. Just thought you might pass that on if it could help find the fix! Quote Link to comment
0 Thom Posted January 3 Share Posted January 3 Any idea when we will see SP3 release. I am having to drop back to 2021 to keep working. 1 Quote Link to comment
0 Lisar Posted January 9 Share Posted January 9 Also frustrated by this issue in version 2022. I was only able to get the plants to set on the surface after moving them to my model layer even though I have a plants layer (and other layers) set to effect the site model. HOWEVER, I still cannot adjust there z value to move them to a specific height. As was noted above, changing the z value does nothing. Selecting the plant in section or 3-d view and trying to adjust the height also doesn't work. Also tried to put a plant into a symbol to try to be able to adjust the height. Didn't work. Hoping a fix for this issue comes out ASAP. 1 Quote Link to comment
0 hollister design Studio Posted January 12 Author Share Posted January 12 Bump. I just checked to see if the fix was 'accidentally' included in SP2.1... No such luck. Hopefully SP3.0 will release fairly quickly! 1 Quote Link to comment
0 Gwendolyn Posted February 21 Share Posted February 21 I'm continuous having this problem. Anyone have any ideas? Quote Link to comment
Issue with z value.
Also:
Also 2:
7 answers to this question
