Bug submitted today, happens on Mac and windows here.
Environment
Vectorworks Version : v2022 SP1.1 (619242)
Vectorworks Product : Design Suite, Renderworks
Operating System : Mac OS 11.6
iMac, 27-inch Mid 2015
3.3 Ghz Quad-Core Intel Core i5
16 GB 1867 MHz DDR3
AMD Radeon R9 M290 2 GB
Bug Title
Curtain wall Bottom Offset fails to extend the wall below 0 from 0 and freezes the application.
Bug Description
Editing an existing curtain wall to have a bottom offset below ‘0’ to be a negative number fails to generate and freezes the application when the bottom offset is at 0. If the Bottom offset is a positive number, then going below 0 the wall will generate. It only occurs when the bottom offset is set at 0 to start.
Steps to Reproduce
1. Open a blank file, draw a standard wall, or a curtain wall from the start.
2. Change the standard wall type to a curtain wall.
3. The bottom bounds should be set to layer elevation.
3. Edit the bottom offset of the wall to be a negative number below 0.
4. Application freezes, requiring a force quit.
What is the expected (correct) behavior?
That the wall will move in the desired direction without freezing.
John Meunier
Any others having the same issue?
Environment
16 GB 1867 MHz DDR3
Bug Title
Bug Description
Steps to Reproduce
What is the current (bug) behavior?
The application freezes.
0 answers to this question
