Curtain wall Bottom Offset fails to extend the wall below 0 from 0 and freezes the application.
John Meunier
Any others having the same issue?
Bug submitted today, happens on Mac and windows here.
Environment
Vectorworks Version : v2022 SP1.1 (619242)
Vectorworks Product : Design Suite, Renderworks
Operating System : Mac OS 11.6
 iMac, 27-inch Mid 2015
3.3 Ghz Quad-Core Intel Core i5
16 GB 1867 MHz DDR3
AMD Radeon R9 M290 2 GB
Bug Title
Bug Description
Editing an existing curtain wall to have a bottom offset below ‘0’ to be a negative number fails to generate and freezes the application when the bottom offset is at 0. If the Bottom offset is a positive number, then going below 0 the wall will generate. It only occurs when the bottom offset is set at 0 to start.
Steps to Reproduce
1. Open a blank file, draw a standard wall, or a curtain wall from the start.
2. Change the standard wall type to a curtain wall.
3. The bottom bounds should be set to layer elevation.
3. Edit the bottom offset of the wall to be a negative number below 0.
4. Application freezes, requiring a force quit.
What is the expected (correct) behavior?
That the wall will move in the desired direction without freezing.
What is the current (bug) behavior?
The application freezes.
0 answers to this question
There have been no answers to this question yet
