I've been experiencing screen flashing and delayed response to changes made in the object info palette as well as crashes if I attempt to make another click in the palette too soon when one of these delays is under way. I have finally captured a file from which part of this is repeatable on my setup. Open the file in VW2021 Attempt to change the background render of the viewport to OPENGL. The image will flash after about ten seconds. There will be no change yet as expected but during this time the OI palette is not responsive and VWs has crashed occasionally to desktop when I try clicking the update button more than once.
Now if you have waited until the flash click the update viewport button. If you fail to move the mouse away from the palette the program is very sluggish in initiating the rendering process.
My OI palette resides over top of the main program window, right side with title bar covering the notification bell. The main window has the navigation - classes palette active & anchored on the right side (and both layers palettes). Hopefully this helps capture this bug (and it is not my GPU hardware failing).
LarryO
VW 2021 SP4.1 (Build 6109975) 64bit
8930 1555 & 1625 Richmond Ave.vwx
0 answers to this question
