Viper x Posted October 27, 2005 Share Posted October 27, 2005 Place plant symbol > from the attributes pallette apply a colour fill to the symbols, usually shades of green. I need to show the line work below, what is the best way to do this please. Thanks Note I have been trying to send the coloured plant symbols "to the back" to make the line work visible but this has no effect ? Well blow me down. I kept messing around and placed new plant symbols on the drawing and I could send them back and the line work was then visible, the ones that could not do this to had the 4 small boxes that show up when you select it with no fill, ie the ones that did work all the their boxes were solid black. What the hell is that about ? [ 10-27-2005, 09:03 AM: Message edited by: Viper x ] Quote Link to comment
islandmon Posted October 27, 2005 Share Posted October 27, 2005 Fill is all about having a 'closed' polygon ... select the Polygon and check the OIP to see if the 'closed' box is checked .. if not then check it. Quote Link to comment
Viper x Posted October 27, 2005 Author Share Posted October 27, 2005 The plant symbols I am using are the ones supplied in the 2d symbol folder so that is not the problem. The problem was these odd selection markers, clearly thay are something different from the norm, ie black filled versions. Quote Link to comment
Marietta Posted October 27, 2005 Share Posted October 27, 2005 VIPER X What about putting your plant symbols on a layer below your line work? Or putting your plant layer as an 'Overlay' in the transfer mode on your layer info box? This gives you some funny colours with the overlay sometimes, but can give you a neat effect. Quote Link to comment
Viper x Posted October 27, 2005 Author Share Posted October 27, 2005 Nice one Marietta, stacking the layers works a treat Thanks for your responses, you are always patience with those of us who's skills lie somewhere other than the Cad drafting side of design. Now back to those different highlight little squares that caused me not to be able to move the symbol forward or back, any ideas what I did to cause them ? Quote Link to comment
TBennett Posted November 9, 2005 Share Posted November 9, 2005 Viper, It sounds like your symbols may be on another layer and you have the Layers> show/snap/modify others option selected. When you are on one layer and select objects on another layer the handles are not filled. Select the objects again and look at the object info to see if this is the case. You can then use the object info tab to move the symbols to the layer you want. Quote Link to comment
