E|FA Posted October 20, 2021 Share Posted October 20, 2021 (edited) I think the video says it all. Anyone at VW want to tackle this one? File available upon request. VW Architect 2022 SP1 - system info in my signature is up to date. UPDATE: I submitted this as a bug report to https://www.vectorworks.net/support/bugsubmit Wall End Cap vs Openings.mov Edited October 20, 2021 by E|FA Update: submitted bug report Quote Link to comment
0 Vectorworks, Inc Employee Matt Panzer Posted October 24, 2021 Vectorworks, Inc Employee Share Posted October 24, 2021 Thanks for submitting this. We’ll get this to the right person to look at. Quote Link to comment
0 Vectorworks, Inc Employee Matt Panzer Posted October 28, 2021 Vectorworks, Inc Employee Share Posted October 28, 2021 On 10/20/2021 at 12:31 AM, E|FA said: I think the video says it all. Anyone at VW want to tackle this one? File available upon request. VW Architect 2022 SP1 - system info in my signature is up to date. Thanks again for reporting this. This issue is being worked on. In the meantime, there is a way to work around it. The problem only happens when two components are merged in 3D. In this case, you can get around the issue by joining the component to the opposite face of wall (highlighting the wall line rather than the component) or to component just before (the core in this case). Like this: ScreenFlow.mp4 1 Quote Link to comment
0 Tobias Kern Posted November 18, 2022 Share Posted November 18, 2022 @Matt Panzer Hi Matt, greetings and hope you are fine. Is there any progress on this behavior so far? I have a lot of problems with bug! Your proposed workaround does not work, if you connect two components. Openings from Doors and Windows will be closed but only with the combined component, the bug only occurs (in my test) from the start point of the wall and only occurs in the first two openings (see attached screenshot and test file = VW 23 SP1.0.2 German Version). Door 1 and 2 is affected. If you delete door 2 then door 3 (= new door 2 after deletion from start) will be affected. BUG: - start from wall - only first two openings Hope we see this bug fixed in VW 2023 and don't have to wait until VW 24. Greetings from Germany Tobi 22-11-18 VW23 BUG components.vwx 1 Quote Link to comment
0 Vectorworks, Inc Employee Matt Panzer Posted November 18, 2022 Vectorworks, Inc Employee Share Posted November 18, 2022 8 hours ago, Tobias Kern said: @Matt Panzer Hi Matt, greetings and hope you are fine. Is there any progress on this behavior so far? I have a lot of problems with bug! Your proposed workaround does not work, if you connect two components. Openings from Doors and Windows will be closed but only with the combined component, the bug only occurs (in my test) from the start point of the wall and only occurs in the first two openings (see attached screenshot and test file = VW 23 SP1.0.2 German Version). Door 1 and 2 is affected. If you delete door 2 then door 3 (= new door 2 after deletion from start) will be affected. BUG: - start from wall - only first two openings Hope we see this bug fixed in VW 2023 and don't have to wait until VW 24. Greetings from Germany Tobi 22-11-18 VW23 BUG components.vwx 8.66 MB · 1 download Hi Tobi, Can you attach a screenshot of the issue you're seeing? In VW 2023 SP1, I no longer see issues with missing components. I do see some issues with pen attributes on the end cap but that's all I noticed in your file. Quote Link to comment
0 Tobias Kern Posted November 18, 2022 Share Posted November 18, 2022 (edited) Hi Matt, greetings. Here you go! In the screenshot, you see the component overwrite the opening of the first 2 openings of the wall, beginning at wall start. This behavior changes, as you flip wall-start-point (2nd wall in the background). Please notice that I used wall end caps with two component on both wall endings! Greetings from Germany and have a nice weekend. Tobi Edited November 18, 2022 by Tobias Kern Quote Link to comment
0 Vectorworks, Inc Employee Matt Panzer Posted November 19, 2022 Vectorworks, Inc Employee Share Posted November 19, 2022 20 hours ago, Tobias Kern said: Hi Matt, greetings. Here you go! In the screenshot, you see the component overwrite the opening of the first 2 openings of the wall, beginning at wall start. This behavior changes, as you flip wall-start-point (2nd wall in the background). Please notice that I used wall end caps with two component on both wall endings! Greetings from Germany and have a nice weekend. Tobi Ah. Thanks for the clarification. I was only looking at these in Top/Plan. 🙂 This looks to be fixed for 2023 SP2. 1 Quote Link to comment
0 rDesign Posted November 19, 2022 Share Posted November 19, 2022 (edited) I have also been having a seemingly related Wall + End Cap + Opening issue in Vw2023 — where if I have a Wall Recess in a Wall and I add a Wall End Cap to the Wall, the Wall Recess will shift out of its correct position by over 1 foot. Then I have to go back and set the correct position of the Wall Recess. Edited November 19, 2022 by rDesign Quote Link to comment
0 Vectorworks, Inc Employee Matt Panzer Posted November 19, 2022 Vectorworks, Inc Employee Share Posted November 19, 2022 7 minutes ago, rDesign said: I have also been having a seemingly related Wall + End Cap + Opening issue in Vw2023 — where if I have a Wall Recess in a Wall and I add a Wall End Cap to the Wall, the Wall Recess will shift out of its correct position by over 1 foot. Then I have to go back and set the correct position of the Wall Recess. Can you attach a file that shows this behavior? Quote Link to comment
0 rDesign Posted November 19, 2022 Share Posted November 19, 2022 (edited) 2 hours ago, Matt Panzer said: Can you attach a file that shows this behavior? I will when I can reproduce it -- right now I'm getting a hard crash from Vw2023 whenever I try to open that same file. Three hard crashes in a row -- in a file that worked fine yesterday. Off to Repair Vw and reset my User preferences. Hopefully that fixes it. EDIT: Nope, after repairing VW and resetting my User Preferences that file still gives me a hard crash upon opening. @Matt Panzer how do I go about recovering a 413MB file that refuses to open? I really do not want to have to rebuild this file as I've been working on it for months, and Levels cannot be transferred between files. (Thankfully, I had a recent backup which *fingers crossed* still works.) Edited November 19, 2022 by rDesign still crashing... Quote Link to comment
0 Tobias Kern Posted November 20, 2022 Share Posted November 20, 2022 18 hours ago, Matt Panzer said: Ah. Thanks for the clarification. I was only looking at these in Top/Plan. 🙂 This looks to be fixed for 2023 SP2. Hi Matt, greetings and Thx for reply. Great to hear it will be fixed in SP2. … just one week to wait for SP2 in Germany Greetings Tobi 1 Quote Link to comment
0 Vectorworks, Inc Employee Matt Panzer Posted November 20, 2022 Vectorworks, Inc Employee Share Posted November 20, 2022 20 hours ago, rDesign said: I will when I can reproduce it -- right now I'm getting a hard crash from Vw2023 whenever I try to open that same file. Three hard crashes in a row -- in a file that worked fine yesterday. Off to Repair Vw and reset my User preferences. Hopefully that fixes it. EDIT: Nope, after repairing VW and resetting my User Preferences that file still gives me a hard crash upon opening. @Matt Panzer how do I go about recovering a 413MB file that refuses to open? I really do not want to have to rebuild this file as I've been working on it for months, and Levels cannot be transferred between files. (Thankfully, I had a recent backup which *fingers crossed* still works.) Can you PM me the file that crashes so I can have a look? 1 Quote Link to comment
0 rDesign Posted November 20, 2022 Share Posted November 20, 2022 2 hours ago, Matt Panzer said: Can you PM me the file that crashes so I can have a look? Absolutely. Thank you! Quote Link to comment
0 Vectorworks, Inc Employee Matt Panzer Posted November 21, 2022 Vectorworks, Inc Employee Share Posted November 21, 2022 22 hours ago, rDesign said: On 11/20/2022 at 9:14 AM, Matt Panzer said: Can you PM me the file that crashes so I can have a look? Absolutely. Thank you! Hey Tim, Thanks for the file and detailed description! Here are my findings: I reproduced the crash on open in VW 2023 SP1 but I do not see it happening in a test build of SP2. However, I did manage to get a crash in SP2 by copying and pasting the suspect walls along with the exterior wall it's joined to into another document. Bug reported: VB-191898 Quote Link to comment
0 rDesign Posted November 21, 2022 Share Posted November 21, 2022 (edited) 1 hour ago, Matt Panzer said: Hey Tim, Thanks for the file and detailed description! Here are my findings: I reproduced the crash on open in VW 2023 SP1 but I do not see it happening in a test build of SP2. However, I did manage to get a crash in SP2 by copying and pasting the suspect walls along with the exterior wall it's joined to into another document. Bug reported: VB-191898 Matt - I’m glad you were able to reproduce the crash. Hopefully that will help lead to a fix in SP3. Thank you! Im curious if you still get the crashes in SP2 if you delete the Wall End Cap before copy & pasting into the new document. [I apologize for my apparent hijacking of this thread, but hopefully my crashes can help lead to a fix for the original topic]. Edited November 21, 2022 by rDesign Quote Link to comment
0 Vectorworks, Inc Employee Matt Panzer Posted November 21, 2022 Vectorworks, Inc Employee Share Posted November 21, 2022 1 hour ago, rDesign said: Matt - I’m glad you were able to reproduce the crash. Hopefully that will help lead to a fix in SP3. Thank you! More than likely it will lead to a fix. 🙂 1 hour ago, rDesign said: Im curious if you still get the crashes in SP2 if you delete the Wall End Cap before copy & pasting into the new document. Now why didn't I think of that! That Wall End Cap was the culprit. You were right all along! Thank you for that suggestion. I'll not this in the bug report. 1 hour ago, rDesign said: [I apologize for my apparent hijacking of this thread, but hopefully my crashes can help lead to a fix for the original topic]. No worries at all. This is all related the Wall End Caps anyway. Thanks again! 1 Quote Link to comment
E|FA
15 answers to this question
