I opened a file in VW2022 (SP1 on win 10) to convert it and all my hardscapes on V_CONC Class have turned to their fill to "solid" with color (a light blue) 'by class" .
The class they are assigned to (V_CONC) has the fill set to Hatch - not to Solid.
When I made the class fill a solid, it defaulted to the lt Blue color, and when I changed the class fill color, the hardscape slab color changed.
But if I change the fill back to a hatch pattern the hardscape no longer follows the fill 'by class'.
Also:
If the Class fill set to hatch I can not change/set a hardscape in that Class to fill to "by class" in the attributes menu - it just flips right back to fill/solid/color 'by class' (using the last color the class hard before it was fill by hatch - if that makes any sense.)
BUT - if I change the Class fill to solid, THEN change the hardscape fill to 'by class', THEN change the Class fill to hatch --- NOW the hardscape shows expected behavior and shows the fill as 'by class' and a hatch.
Also - if I tried to set a hardscape to fill /hatch in the attributes menu I get an error "Hatch and Tile fills are disabled for the hardscape"
Attached a test file with a hardscape copied from original file and a rectangle converted to a hardscape:
hollister design Studio
Also:
blue hardscapes.vwx
Hardscapes are as expected back in 2021
Edited by hollister design StudioLink to comment
9 answers to this question
