sivonen Posted October 19, 2021 Share Posted October 19, 2021 Hello, I recently updatet to VW2022 and I am noticing the same thing in all old files that are made with VW 2020 or 2021. This does not happen when I create a new file with VW2022 and just make a new device. Any connections made on "wrong side" of device (meaning input on right side or output on left side) makes the Cable Number and Connector Type text go upside down. Strangely this effect does not happen when looking at the connectors inside the device object. Since I'm usually drawing larger interconnected systems where the i/o flow might not be defining the logic of the schematic, as networked and control systems become more complicated, this is a major issue for me in all my scematics. Quote Link to comment
Vectorworks, Inc Employee Conrad Preen Posted October 21, 2021 Vectorworks, Inc Employee Share Posted October 21, 2021 Hi @sivonen Could you send us a file that shows the issue? Conrad 1 Quote Link to comment
sivonen Posted November 3, 2021 Author Share Posted November 3, 2021 File sent with direct message -Janne Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted November 3, 2021 Vectorworks, Inc Employee Share Posted November 3, 2021 Hello @sivonen, The problem here is that you have your view set to "Top" and not "Top/Plan". If you do this in VW2021 you will get the same result. What is happening here is that in VW flipped text like this can get adjusted automatically in Top/Plan so that it is readable, using the "Adjust Flipped Text" document preference. However, this is not the case in 3D views, such as Top. So, in order to get this working as before, just switch the view to Top/Plan. 🙂 Best Regards, Nikolay Zhelyazkov Quote Link to comment
