create wall recess not working
Ride
I'm not very experienced in using wall recesses (or projections), but it seems like it should be pretty straightforward. I can't figure out why I get the small portion of wall at the end of this wall? My 3D object extends beyond the wall, so I would assume it would cutout the wall completely. Why is it leaving this small bit on the end?
Thanks
VW Walls are a bit limited to many Actions located at the Wall Ends.
What works like a charm inside a Wall may cause problems at their end.
You could try with 2 Windows (set to "Opening only",) where the 2nd,
higher Window exceeds the Wall (?)
Edited by zoomer
Ha. I thought of that, but then I also thought I need to learn some of the wall functionality better so I gave the recess thing a try. I will now go back to my first approach. A vector workaround.  Thanks for the reply.
1 hour ago, MarcelP102 said:
Have you tried using the reshape function for editing the shape of the wall? In my experience using wall recess and wall projection don't work nice at wall ends.
I did try that, but that just made a mess of things. I find making any changes to walls to be a problematic affair....
