Eric Mousse Posted October 15, 2021 Share Posted October 15, 2021 Since the 2022 SP1 update I no longer have access to the window or door settings. Anyone else having the same problem? Quote Link to comment
0 Administrator JuanP Posted October 15, 2021 Administrator Share Posted October 15, 2021 @Eric Mousse unfortunately, I can't replicate the issue. Try the following: 1. Shutdown Vectorworks and reboot the system and try again 2. Rename the Vectorworks User Folder and try again 3. if the problem persist - reply back with your macOS and specs. Quote Link to comment
0 Administrator JuanP Posted October 15, 2021 Administrator Share Posted October 15, 2021 @Eric Mousse Update: “We have found an issue with Vectorworks 2022 SP1 running in operating systems where the locale is different from English. This is an issue for all system locales that are not using the dot (.) as a decimal separator. Our R&D team is looking into this issue. In the meantime, you can change the Language/region preference to English, or under the Advance, tab select the number separators to (.) instead of (,) and restart Vectorworks. Please stay tuned for more information.” 2 Quote Link to comment
0 drelARCH Posted October 15, 2021 Share Posted October 15, 2021 @Eric Mousse thanks for question. I am having same issues since SP0. No way to edit windows/doors style. Will try now number separators suggestion. Quote Link to comment
0 Trend Setting Design Posted October 15, 2021 Share Posted October 15, 2021 I am using VW 2022 and am having a problem with my doors NOT showing up in the viewport. The show up on the Design Layer...I have checked my classes...what could it be? On the view port plan the door shows up in the wall but the swing does not. If I go into the pallet info - 3D- ...and check off show swing, the swing shows up on plan in the viewport but the door opening does not show up in the wall???? Any Suggestions??? Quote Link to comment
0 zoomer Posted October 15, 2021 Share Posted October 15, 2021 Hmmh ... I have german qwertz layout with "comma" in NumBlock, using german language settings on Mac and PC with "comma" as a decimal separator. But so far I was able to edit my Window, Door, Railing, Slab, Wall - Styles in VW 2022 fine. Even all File stuff migrated from VW 2021. (Win19 21H1 or macOS 12 Monterey PB on M1 Mini) Quote Link to comment
0 Eric Mousse Posted October 15, 2021 Author Share Posted October 15, 2021 @JuanP It works well choosing the region USA in System preferences. Thanks for the tip ! 1 Quote Link to comment
Eric Mousse
6 answers to this question
