willofmaine Posted October 14, 2021 Share Posted October 14, 2021 When I use the "Solid Boolean" node to try and combine two symbols, one of which is scaled, as a solid addition, it doesn't work. If neither symbol is scaled, a solid addition is generated as expected. See attached. How are scaled symbols added together with Marionette? Thanks! 03-Add Scaled Symbols-02.vwx Quote Link to comment
Marionette Maven Marissa Farrell Posted October 14, 2021 Marionette Maven Share Posted October 14, 2021 The scale symbol node is outputting incorrect values. In the script, change the s in the last line to i and you'll get what you're looking for. Logging this as a bug now, thanks for finding it! Quote Link to comment
willofmaine Posted October 14, 2021 Author Share Posted October 14, 2021 (edited) That worked great in the file that I sent you! But not so much in my original file (attached).... When I changed the "s" to an "i" in the file that I sent you, I got a dialogue box about a "REFFILE keyword" (see screenshot in attached file) to which I said "Yes." When I went to update the node in my original file, the "s" had already been replaced with the "i" (which I assume has to do with the "REFFILE" thing...). But the network failed... Ultimately, I found that if I copied the node that I'd originally modified and used that, the network would succeed and generate the expected solid. The attached file displays the steps I went through. It also includes a screenshot of a warning that I frequently get. And I've noticed that the Scale Symbol node has a red gradient in the RM, but in the file it's just white... don't know if that's significant. VWIS219 Thanks! Will 05-Scale Symbol Node-02.vwx Edited October 14, 2021 by willofmaine Quote Link to comment
willofmaine Posted October 19, 2021 Author Share Posted October 19, 2021 Hi @Marissa Farrell, just wondering if you saw my above post and have had a chance to look into it? Changing the "s" to an "i" seemed to work only for the node that I changed. All other instances of the node seemed to automatically have their "s" changed to an "i," but they wouldn't work. Is this a bug, or am I missing something? Thanks! Quote Link to comment
Marionette Maven Marissa Farrell Posted October 26, 2021 Marionette Maven Share Posted October 26, 2021 Sorry @willofmaine, I was off on vacation last week. I am looking right now! Quote Link to comment
Marionette Maven Marissa Farrell Posted October 26, 2021 Marionette Maven Share Posted October 26, 2021 I looked over these files and did not see that all of the scale symbol nodes had the "i", I often still saw an "s" When I updated these, all of the networks worked identically. Quote Link to comment
willofmaine Posted October 26, 2021 Author Share Posted October 26, 2021 Hmm... I just went through each scale symbol node, and here they all have the "i" (assuming we're looking at the very last character of Line 36, see Screenshot 07). I started from scratch in a new file (File 08) and had the same issues. The node from the Resource Manager fails to create a solid, but when replaced with a copy of the node that works from File 05, a solid is created as expected. What is the REFFILE all about? After I changed that first node, they all have the "i" (here they do, at least...). Oddly, I just found that after opening and closing the node's script, a solid then is created as expected... See Screen Recording 09. The recording also shows an error message, which I often get just when opening a file and pretty much always ignore... 09-Screen Recording-08.mov 08-Scale Symbol Node-00.vwx Quote Link to comment
Marionette Maven Marissa Farrell Posted October 27, 2021 Marionette Maven Share Posted October 27, 2021 REFFILE is used for updating the scripts across all your nodes, it's useful when a node has a bug and needs to be updated in the source code, but what you've stumbled across is the small issue - each existing node in your document must be updated to refresh the script (so each time you open and close the node it will update it, but you need to do that for each existing node in your drawing). I *think* you could also use the "Tools > Utilities > Reset All Plug-ins" command to refresh the script, but I am not 100%. Quote Link to comment
willofmaine Posted October 27, 2021 Author Share Posted October 27, 2021 Okay... got it. I went into the "Marionette Default Library.vwx" file, edited the Scale node's symbol, opened and closed the node's script there, and now when I place it in a new file it works as expected. (And while I was at it, I edited the node's Symbol Options so that it places into the Operations class rather than the Active class...). How do I disconnect a node from the REFFILE function? So that, you know, I can mess around with its script without affecting all instances of that node... Thanks! Quote Link to comment
Marionette Maven Marissa Farrell Posted October 27, 2021 Marionette Maven Share Posted October 27, 2021 You can just delete the line that says REFFILE, all of the gray text there 🙂 Quote Link to comment
willofmaine Posted October 27, 2021 Author Share Posted October 27, 2021 Oh, that's easy. I thought of that, but also thought everything after the " # " was just commentary. Thanks! Quote Link to comment
