Flat DXF to Extruded Model
trashcan
I've done this a few times now and I'm looking for best practices / a faster solve.
I got this DXF from the manufacturer:
I then go through and delete all the junk I don't care about:
I then do that in a fine tuned way trying to delete all the artifact junk from the DXF:
Then I pick a surface as my base extrude and use the command "Combine Into Surface" and extrude it to the depth that I want:
Then I rinse and repeat for all the other blocks and then combine at the end. Is there a faster / smarter way to do this?
Unless you manage to get hold of Harry Potter's magic wand then probably not. 🙂
You could try to create only the base volume without rounded edges, then put the side surface areas to each respective side and use push/pull to subtract/extrude to the desired depths first and then round all corners where necessary. That is how I would do it in my other CAD program which can recognize enclosed surface boundaries for push/pull but in VW it doesn't work as smoothly so that is one thing where I would like to see VW improve.
