tismacfan2 Posted October 13, 2021 Share Posted October 13, 2021 Is there a reason I can't see layers of different scale at the same time? Pascal Quote Link to comment
Hans-Olav Posted October 13, 2021 Share Posted October 13, 2021 If you uncheck unified view you should be able to see them https://app-help.vectorworks.net/2021/eng/index.htm#t=VW2021_Guide%2FViews%2FUnified_layer_view.htm&rhsearch=unified view&rhhlterm=unified view&rhsyns= Quote Link to comment
zoomer Posted October 13, 2021 Share Posted October 13, 2021 There is a Sub Setting in Unified View (double click the Icon), which "ignore Layers of different scale" which will hide these when activated. So you can have Unified View activated to see all Layers. (I use to have all Layers at same scale though) Unified View itself is basically to control if other Layers will follow the View Navigations of the Active Layer. If UV off, the non-active Layers will just stay where they are when navigating the view ..... 3 Quote Link to comment
