Ian5100 Posted October 12, 2021 Share Posted October 12, 2021 I am trying to create a new numbering system to match my company's standard. Whenever I finish and hit "OK", I get a popup saying "Number systems file not updated." Then when I open the settings again, all of my changes to the Numbering tab have vanished. Has anyone else encountered this? P.S. I am in v2021 on a Windows machine. Quote Link to comment
Ian5100 Posted October 12, 2021 Author Share Posted October 12, 2021 It seems that I have solved my own problem. Once I attempted to edit the "Numbering" XML file in the "connectCAD_Data" folder and had to enter admin credentials in order to save the changes that I made, I was able to successfully edit numbering systems within the program. Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted October 13, 2021 Vectorworks, Inc Employee Share Posted October 13, 2021 9 hours ago, Ian5100 said: It seems that I have solved my own problem. Once I attempted to edit the "Numbering" XML file in the "connectCAD_Data" folder and had to enter admin credentials in order to save the changes that I made, I was able to successfully edit numbering systems within the program. Hello @Ian5100, Correct. This message would appear if your numbering system file is not writable. You have made your file writable and that is why everything works as expected now. Best Regards, Nikolay Zhelyazkov Quote Link to comment
