  • 1
Monterey PB 9 - shut down freezing VW
zoomer
9 answers to this question
Funny, I tried a blank File and closing VW by Menu File > Quit
Activity Monitor "VW is unresponsive"
> Force Quit.
I thought about write right missing or lost for drives in Mac Settings Privacy or such.
(Although my files were still saved well)
So I opened just VW without opening any File.
Closing VW by Menu File > Quit
> Force Quit.
So I think this is something bigger Monterey and or VW thing .....
Another thing where I am not sure if it was always or now with Monterey PB 9 only ...
When I set my 3D view to (new) HL.
There often remains or comes back a busy "Render in Action" Tea Pot Icon,
in right bottom corner of the view window, similar to rendering RW Styles,
although I can navigate my 3D view fine.
It may re-appear after I end rotating my view.
Is it really busy calculating still (or again), or just a UI failure ?
BTW,
Would it be possible that (new) HL is able to display intersection Lines,
between crossing Surfaces ?
E.g. like for where Walls enter a ground Volume - like (old) HL could by
activating certain settings.
EDIT :
for a few moments I can even see these lines temporarily while zooming.
But in general they are just missing and intersections only recognizable,
by the side edges of the Walls being cut, at the intersection point with
the ground. Which looks a bit fuzzy.
Attached a Screenshot of my parking places above terrain for better understanding ....
EDIT EDIT :
When I switched backt to my VW again after Safari,
the Lines that I want in (new) HL, came back (temporarily).
So it would (and should) look like this ....
Attached 2nd Screenshot :
Edited by zoomer
  • Administrator
On 10/7/2021 at 6:23 PM, zoomer said:
I updated to macOS 12 Monterey PB 9.
Now VW will not shut down correctly anymore on my M1 Mini.
I save my file and want to close VW.
It will freeze and don't free memory.
The only thing I can do is to force quit.
Anybody else ?
@zoomer I got confirmation from R&D that this issue has been fixed in PB 10 - can you confirm?
9 minutes ago, Christiaan said:
I just updated my Monterey beta to 12.0 Beta (21A5552a) yesterday and it's still a problem.
Hi Christiaan, Can you provide some more information on this?  We are not seeing this crash anymore.
What version of VW are you using and what build?  Do you get a crash log?  What is the behavior that you see on quit?
Thanks!
Yes, I mentioned that in another Thread.
I installed PB 10, macOS 12.0 (21A5552a) yesterday and can confirm
that VW can quit normally again for me.
(But AFAIK I tried only a single time)
