michaelk Posted October 5, 2021 Share Posted October 5, 2021 I'm trying to do a 3D rotation (Set3DRot or SetRot3D) on a group that was created by using SymbolToGroup(h,2); I can't figure out a way to get the handle to that group. LNewObj doesn't do it. I've tried BeginGroupN(hGroup); and running the SymbolToGroup inside that group so I could get a handle, but that doesn't work. Tried a Waldo. No luck. Any thoughts? Quote Link to comment
Julian Carr Posted October 5, 2021 Share Posted October 5, 2021 Try this: SymbolToGroup(h1, 2); hGroup := NextObj(h1); Quote Link to comment
michaelk Posted October 5, 2021 Author Share Posted October 5, 2021 Nope. looking at Debugger. groupHandle never gets assigned. PROCEDURE TEST; VAR h,groupHandle : HANDLE; BEGIN Symbol('Test Symbol',0,0,0); h := LNewObj; SetView(#-90d,#0d,#0d,0",0",0"); SymbolToGroup(h,2); groupHandle := NextObj(h); SetRot3D(groupHandle,#90d,#0d,#0d,0,0,0); END; RUN(TEST); Quote Link to comment
Julian Carr Posted October 5, 2021 Share Posted October 5, 2021 It works in my code as does this: BeginGroup; Symbol(GetSymName(hSym), x1, y1, GetSymRot(hSym)); SymbolToGroup(LNewObj, 2); EndGroup; hGroup := LNewObj; But does SetRot3D() support groups? Quote Link to comment
michaelk Posted October 5, 2021 Author Share Posted October 5, 2021 I've been trying both SetRot3D and Set3DRot (because I can't remember which is which and it feels faster to try both than look it up and retain it :-). Procedure Set3DRot rotates the referenced 3D object about a specified 3D point. It works with the following 3D objects: extrude, multiple extrude, sweep, mesh, 3D polygon, solid, CSG solid, group, symbol, plug-in object, NURBS curve, NURBS surface. Quote Link to comment
Julian Carr Posted October 5, 2021 Share Posted October 5, 2021 FWIW, I always use Set3DRot() Quote Link to comment
Julian Carr Posted October 5, 2021 Share Posted October 5, 2021 Maybe it only works in PIOs, which is where I am using it? Quote Link to comment
michaelk Posted October 5, 2021 Author Share Posted October 5, 2021 Could it be because the symbol is hybrid? How would I strip it down or extract the 3D from the symbol definition? Quote Link to comment
Julian Carr Posted October 5, 2021 Share Posted October 5, 2021 Assuming this is just a script not a PIO, this should work: VSave('XYZ'); DoMenuTextByName('Standard Views', 2); { top} Explode; VRecall('XYZ'); VDelete('XYZ'); Also, the following will be true for a 3D object (mostly): GetObjectVariableBoolean(h1, 650); Quote Link to comment
michaelk Posted October 5, 2021 Author Share Posted October 5, 2021 It's a script until I figure it out. Then I want it to be a PIO. Tell me more about Explode. My function reference doesn't have an Explode function. Is that Australian only? 🙂 Quote Link to comment
Julian Carr Posted October 5, 2021 Share Posted October 5, 2021 Explode = SymbolToGroup() = STG. If it will be a PIO and you want to rotate a symbol in the Z axis, then it must not be hybrid. You will need to investigate a way to restore the view after you switch it to 3D for the STG. Alternatively if the symbols don't contain groups or nested symbols, then you could get a handle to the symbol definition, enter the definition, loop through and duplicate 3D objects then use SetParent() to move them to the PIO, all within BeginGroup/EndGroup, then rotate the group. 1 Quote Link to comment
MullinRJ Posted October 7, 2021 Share Posted October 7, 2021 @michaelk, Why not place your symbol, rotate it in 3D (or set its 3D angles), THEN convert it to a group? If it is a Hybrid Symbol, you will be limited to Z-axis rotations only. If it is a Hybrid Symbol and you want XY-axis rotations, duplicate the symbol definition, remove all 2D parts, then place the new symbol, rotate, and "explode". Delete the duplicate if desired. Raymond Quote Link to comment
