DB Clarke Theatre Posted October 4, 2021 Share Posted October 4, 2021 When I imported my 2019 plans to Vectorworks 2021, the ganging of my lighting instruments got all screwed up. For the simple fixtures I can easily re-do it. For the multi-circuited cyc-lights however, I can no longer gang a single cyc cell to a cell from a neighbouring fixture. I was able to do this easily in previous versions, but now the ganging tool will only select the whole multi-circuit instrument, and connects the ganging line from centre to centre of the larger fixture rather than the desired single cell. 1 Quote Link to comment
mjm Posted October 5, 2021 Share Posted October 5, 2021 20 hours ago, DB Clarke Theatre said: When I imported my 2019 plans to Vectorworks 2021, the ganging of my lighting instruments got all screwed up. For the simple fixtures I can easily re-do it. For the multi-circuited cyc-lights however, I can no longer gang a single cyc cell to a cell from a neighbouring fixture. I was able to do this easily in previous versions, but now the ganging tool will only select the whole multi-circuit instrument, and connects the ganging line from centre to centre of the larger fixture rather than the desired single cell. Same. So in order to solve this I had to hang the cyc system as individual cells in order to gang em. Oy. Quote Link to comment
