max-is-on-board Posted October 1, 2021 Share Posted October 1, 2021 Hello everyone, I have a list with several Chunks of numbers inside. I want to sum the numbers of each chunk so in the end I will have a list of sums to further process in the script. I have tried to use the "add list" node but a problem occurs. The "add list" node can only add together numbers that are on the initial branch of the list. Do you know how to add together each branch of a list if there are several numbers on each branch? Is there a node I am missing or a work-around? I am very grateful for your help and looking forward to continue working on the script. Best, Max! Quote Link to comment
m.graf Posted October 4, 2021 Share Posted October 4, 2021 Unfortunately, I do not fully understand what you are looking for, but this node occurs to me spontaneously Quote Link to comment
