Texture from hatch
KrisM
Discovered this option to create a texture but can't seem to make it work.
Select a hatch in the Resource Browser. Right click and select texture from hatch. Dialog comes up to name the new texture. So far so good.
When I go to use the new texture, nothing shows up. No texture shows. In the preview of the texture, it is just white, no lines are showing.
I'm thinking that this may be a problem in 2022.  So I try 2021 and get the same result.
Any suggestions. VW usually has a hidden something somewhere to make things work.
6 answers to this question
I wasn't aware of the 'Create Texture From Hatch...' command but seems a bit of a strange workflow. You still need to create the texture by adding an image or whatever. Like Zoomer says the normal workflow would be to start with a texture then add a surface hatch to it rather than the other way around. But perhaps this option is designed for circumstances where you are only rendering in Hidden Line + are concerned only with seeing a surface hatch + not textures? i.e. it creates a surface-hatch-only texture for use in Hidden Line renderings only + not in OpenGL or Renderworks...?
It's not really a question about whether this is a good workflow but rather, how does this work. On inspection this morning, I see that the command simply inserts the hatch into the texture but doesn't actually create anything to do with the image. Not really useful as has been pointed out. I was hoping that the command would generate the image portion of the texture from the hatch. That would be useful to me.
