Pad w/ Retaining edge edits
v2022
If editing a pad retaining edge z value, how does one select a facet/side of the retaining edge polygon?
OIP Move option is set to Retaining Modifier Edge.  Or maybe this is not intent? Or this is a bug that facets cannot be selected or moved ?
vwx Help seems to indicate it's possible:
Move  (Pad with retaining edge only)
Select the portion of the retaining edge modifier to edit (vertex or edge), and then edit its Z value, or scroll through its vertices with the left and right arrows and change the selected vertex Z value.
Several issues if the OIP Move option is Retaining Modifier Edge
  • If the Retaining Edge poly is non planar (vertex z values vary), change to OIP z value flattens the poly so that all vertices have same, new z
  • Click Edit arrows - the entire poly highlights (well, maybe not one facet), the various vertices highlight, but not individual edges/sides between the vertices.
  • If the Reshape tool is activated, any vertex can be z adjusted by dragging (might need to disable snaps), but facets cannot be selected and moved. eg, marquee select is not available.
Workaround is to move individual vertices.
-B
Edited by Benson Shaw
v2022
