How to check Angle (direction) of Dimension
DomC
Dimension Direction.vwx
Hello
I am able to check if a Dimension is vertical or horizontal with
direction = vs.GetObjectVariableReal(dim,value)
On my mac version, it returns 0 for horizontal and 1.0 or -1.0 for vertical Dimensions. Unfortunately this seems not to work on Windows. There is always 0.0.
I could test if xDiff is bigger than yDiff (of the Dimension Points) an decide it is horizontal but this can result in errors with some dimensions.
Anyone has an Idea to get that information reliable?
Edited by DomC
Hi Dom,
Try this:
Procedure T;
VAR
    h1 : HANDLE;
    b1, b2, b3 : BOOLEAN;
    i1 : INTEGER;
    r1, rAngle : REAL;
BEGIN
    h1 := FIn3D(FSActLayer);
    REPEAT
        IF (GetType(h1) = 2) THEN BEGIN
            GetMarker(h1, b2, b3, i1, r1);
            IF b2 | b3 THEN BEGIN
                b1 := True;
                rAngle := HAngle(h1);
            END;
        END;
        h1 := NextObj(h1);
    UNTIL (h1 = Nil) | b1;
    Message('Angle is: ', rAngle);
END;
Run(T);
Even better as a function:
Function GetDimAngle(h1 : HANDLE) : REAL;
VAR
    h2 : HANDLE;
    i1 : INTEGER;
    r1 : REAL;
BEGIN
    h2 := FIn3D(h1);
    REPEAT
        IF (GetType(h2) = 2) THEN BEGIN
            GetMarker(h2, b2, b3, i1, r1);
                b1 := True;
                GetDimAngle := HAngle(h2);
            END;
        END;
        h2 := NextObj(h2);
    UNTIL (h2 = Nil) | b1;
END;
Fantastic Julian this is a very reliable solution, Thank you. I implemented this way:
dim = vs.FSActLayer()
def GetDimAngle(h1):
    h2 = vs.FIn3D(h1)
    DimAngle = 0
    while h2 != vs.Handle(0):
        if vs.GetTypeN(h2) == 2:
            BOOLEAN, style, angle, size, width, thicknessBasis, thickness, visibility = vs.GetObjBeginningMarker(h2)
            if style:
                DimAngle =  round(vs.HAngle(h2),0)
        h2 = vs.NextObj(h2)
    return DimAngle
DimAngle = GetDimAngle(dim)
vs.AlrtDialog(str(DimAngle))
  • 5 months later...
