  • 6
Add ability to Purge Screen Plane Objects in VW2022
E|FA
2 answers to this question
I wrote a simple python script that may help.
This script will change any screen plane object in the drawing to Layer Plane.
Once run you can disable "enable legacy 2D features" on the "2D legacy mode" tab in document settings.
Notes:
	1. Some objects may move to the 3D plane and not the Layer Plane.
	2. You will also have to run this script on any referenced files first.
This Python Script may be freely distributed. No warranty provided.
Use at your own risk.
David Hamer, 2021 revision 09-23-2021
def assign(h):
	vs.SetObjectVariableBoolean(h,1160,False)
vs.ForEachObject(assign,"(INVIEWPORT & (PLA='Screen Plane'))")
Script Screen Plane to Layer Plane.vwx
