matteoluigi Posted September 20, 2021 Share Posted September 20, 2021 In general objects, which are above the normal floor plane cut plane (in general the height in Europe is 1m), are shown with a dashed line. I remember that this idea has ended as a new feature a few years ago. However it only seems to work partially to me. - Wallll-objects UNDER the cut plane (especially walls) work fine. - Walls and Slabs over the cut plane instead don't work. - Slabs also aren't shown with their material hatch when in cut plane and aren't shown dashed, when they lay above the cut plane. - Walls aren't shown dashed, when they are situated above the cut plane. So actually I think I have to model every wall above the cut plane as a 3d-volume and create an autohybrid symbol from it, in order to integrate it as good as possible in our BIM-Model. Right? Quote Link to comment
shorter Posted September 21, 2021 Share Posted September 21, 2021 Draw the objects above the cut plane as linework. They are indicative. No one builds a object shown dotted above. You issue an RCP for construction of objects above the cut plane. Quote Link to comment
DBrown Posted September 22, 2021 Share Posted September 22, 2021 On 9/20/2021 at 11:12 AM, matteoluigi said: In general objects, which are above the normal floor plane cut plane (in general the height in Europe is 1m), are shown with a dashed line. I remember that this idea has ended as a new feature a few years ago. However it only seems to work partially to me. - Wallll-objects UNDER the cut plane (especially walls) work fine. - Walls and Slabs over the cut plane instead don't work. - Slabs also aren't shown with their material hatch when in cut plane and aren't shown dashed, when they lay above the cut plane. - Walls aren't shown dashed, when they are situated above the cut plane. So actually I think I have to model every wall above the cut plane as a 3d-volume and create an autohybrid symbol from it, in order to integrate it as good as possible in our BIM-Model. Right? You are out of luck, the Cut Plane is half baked, it only would work with walls, and nothing else, you will have to use 2D linework to represent projected objects, like slabes above or roof above and the list goes on... Quote Link to comment
matteoluigi Posted September 22, 2021 Author Share Posted September 22, 2021 Just now, DBrown said: You are out of luck yeah, that's what I actually "was afraid of"... I mean, in university and every technical drawing school you learn that you have to show all objects, covered ones and invisible ones (above the cut plane) in different dashed line types. Now the future is BIM and now I have to draw everything in lines again? Why do I do BIM then? Sounds to me quite antiquated... pity but, somehow symptomatic for many tools in Vectorworks, good ideas but half baked 😞 1 Quote Link to comment
DBrown Posted September 22, 2021 Share Posted September 22, 2021 You can try to use the horizontal section Viewport option too, but guest what, is half baked too Quote Link to comment
line-weight Posted September 22, 2021 Share Posted September 22, 2021 I agree it's not really good enough that you have to add detail in 2D linework (which has to be manually updated at every revision), in a "BIM" workflow. Have a look at the approach explained at the end of this thread I still want to look at this more closely to understand how it works but in principle there might be a way of using this type of method to get your overhead lines. 1 Quote Link to comment
MBruno-JDB Posted August 21, 2023 Share Posted August 21, 2023 Our drawings symbolically show all objects above the cut plane in a dashed line. We created a project parameter in our template called "Visibility Style". That parameter is linked to a series of filters that override the line styles. All we have to do for each item is set the Visibility Style to Above and those items show in the line style we want without having to linework or draw detail lines, which are both view specific. The filters are set up in each of our View Templates, so we only have to change the Visibility Style once. 3 Quote Link to comment
line-weight Posted August 22, 2023 Share Posted August 22, 2023 14 hours ago, MBruno-JDB said: Our drawings symbolically show all objects above the cut plane in a dashed line. We created a project parameter in our template called "Visibility Style". That parameter is linked to a series of filters that override the line styles. All we have to do for each item is set the Visibility Style to Above and those items show in the line style we want without having to linework or draw detail lines, which are both view specific. The filters are set up in each of our View Templates, so we only have to change the Visibility Style once. I don't quite follow your description. What do you mean by "project parameter"? You have a parameter called "visibility style" but this is a parameter of what? When you talk about "items" do you mean objects in the model? Or, for example are you talking about viewports? What is a "view template"? 2 Quote Link to comment
matteoluigi Posted August 23, 2023 Author Share Posted August 23, 2023 @MBruno-JDB which "series of filters" are you talking about? What you say sounds really interesting, however I don't get it because it's still to abstract 🙂 Quote Link to comment
Tom W. Posted August 23, 2023 Share Posted August 23, 2023 Record Formats + Data Visualisation...? Quote Link to comment
matteoluigi Posted August 23, 2023 Author Share Posted August 23, 2023 Or working with the Vectorworks Datamanager??!? let's say, the we define a field in a record format which subtracts the design layer cut plane elevation from the height above layer elevation for all objects. then we define a data vizualization that defines that all objects with a value bigger than 0 have to be drawn with a dashed line type (unless you don't put off a checkbox, that defines, that that object has to be drawn with a solid line, despite of the fact, that it's situated above the layer cut plane). could be worth an approach... However, I am curious on what @MBruno-JDB answers on our questions 😉 1 Quote Link to comment
