show objects above cut plane as dashed line without necessity of auto hybrid objects
matteoluigi
In general objects, which are above the normal floor plane cut plane (in general the height in Europe is 1m), are shown with a dashed line. I remember that this idea has ended as a new feature a few years ago.
However it only seems to work partially to me.
- Wallll-objects UNDER the cut plane (especially walls) work fine.
- Walls and Slabs over the cut plane  instead don't work.
- Slabs also aren't shown with their material hatch when in cut plane and aren't shown dashed, when they lay above the cut plane.
- Walls aren't shown dashed, when they are situated above the cut plane.
So actually I think I have to model every wall above the cut plane as a 3d-volume and create an autohybrid symbol from it, in order to integrate it as good as possible in our BIM-Model. Right?
You are out of luck, the Cut Plane is half baked, it only would work with walls, and nothing else, you will have to use 2D linework to represent projected objects, like slabes above or roof above and the list goes on...
Just now, DBrown said:
You are out of luck
yeah, that's what I actually "was afraid of"... I mean, in university and every technical drawing school you learn that you have to show all objects, covered ones and invisible ones (above the cut plane) in different dashed line types. Now the future is BIM and now I have to draw everything in lines again? Why do I do BIM then? Sounds to me quite antiquated... pity but, somehow symptomatic for many tools in Vectorworks, good ideas but half baked 😞
I agree it's not really good enough that you have to add detail in 2D linework (which has to be manually updated at every revision), in a "BIM" workflow.
Have a look at the approach explained at the end of this thread
I still want to look at this more closely to understand how it works but in principle there might be a way of using this type of method to get your overhead lines.
