I have more than 1 viewport on a sheet layer - I enter 'edit viewport annotation' to edit - when I exit out of the edit mode one or more viewports are no longer there.
this is not good.
Current example:
Here is a sheet I'm getting ready for a revision release - I just need to add one more callout:
Now I go into Viewport 1 to edit the annotations - when I come out - Viewport 2 the elevation is gone:
In this case viewport 2 was connected to the elevation marker in Viewport 1.
So I reenter annotation space and select the elevation marker.
Then in the OIP I used "navigate to viewport" to see where the heck it's gone off to.
Here is the result:
The view is zoomed out very far.
Yet when I 'select all' there are still only two object - viewport 1 and the title block border.
Where did Viewport 2 go?
Now the weird part...
I generally keep my viewports on the NONE class.
in this case BOTH viewports 1 and 2 are on the none class.
The None class is visible and I can see viewport 1.
Just to make sure I turn the None class off and back on...
Now both viewports are visible again.
What is going on?
Hardware:
I have an AMD RADEON PRO WX3200 card (which is the current version of the Radeon Pro WX 3100 which is on the "QUALITY-TESTED HARDWARE' approved for VW2020 list).
hollister design Studio
This happens fairly often.
this is not good.
Current example:
Here is the result:
What is going on?
Hardware:
Most current driver 21.Q1.1/OpenGL 4.6/4GB vram
0 answers to this question
