VW2022 changed my VW2021 settings...
So I'm an idiot...
I thought I could download and look round VW 2022 with out it changing anything on my current setup.
What can I say, I like new toys...
It (of course) changed my file associations (without asking) - no a big deal - I just reset .vwx to VW2021
But it also seems to have reset my preferences.
So far it's changed my user data and prefenaces  folder location and deleted my workgroup and project folder locations:
It's also locked out my ability to change any preferences so I can't reconnect to my workgroup or to my data folder.
Also can I connect 2022 to the same preferences folder?
Will that allow me to use the same plant symbols (i realize there are changes to plant symbols in 2022) and workspaces (probably changes here too)?
I've turn off 2022 and am trying to get back to work with 2021 for the rest of the day.
What did I do wrong?
The more I look, the more went wrong...
ALL my settings are back at default.
All my select similar  presets are gone.
All my favorites have been disassociated - the files are still there so I can re do them at least.
All my double click does this action setting have to be redone.
Small things maybe, but I keep using my normal workflow and realizing that it didn't work and then have to figure out what the VW 2022 install changed on my VW 2021
Not cool Vectorworks.
My condolences.  I remember experiencing something similar when test driving 2019.
Now, everytime I customize something from the standard installation of a software, it goes into a spreadsheet so I have a reference for recreating things.
It's so frustrating to have these kinds of changes reveal themselves for weeks after the initial breakage due to the workflows used to define a project.
Did you either:
  • Point VW2022 to your VW2021 user folder under VW Prefs?
  • Use the Migration Manager, and perhaps set the destination to your VW2021 user folder?
Aside from that I see no reason that what you're describing should've happened.
4 hours ago, hollister design Studio said:
Which version is this screenshot from?
What exactly do you mean by  "reset .vwx to VW2021"?
Andy - I closed 2022 and left it alone until I had some time.
I was wondering if I could point it to 2021 or use the migration manager?
I know there are quite a few changes in 2022 (Plant Objects have extra features - root ball and drip zone - for one) and I wonder if they are backward compatible?
I looked around the 2022 page and didn't see anything about this - but I also didn't see anything saying Installing 2022 was going to reset all my 2021 setting to default.
I don't want to frag my working setup any more than I already have...
That was from 2021 when I was trying to get back to work.
That is not the location of my 2021 data - I had it pointed to a different drive where it was backed up and shared between computers.
I did reset the location and most everything is working now.
I reset my "open with" settings so when I click on a .vwx file it opens with 2021
@Andy Broomell I am on VW2021 + am downloading VW2022 as we speak... Could I ask what you consider to be the best procedure for transferring workspaces/settings/templates/libraries over from one version to the next? I just want to have a look at VW2022 at this stage + get to know the new features whilst carrying on the bulk of my work in VW2021. I've only attempted to migrate once before - from VW2020 to VW2021 - and I seem to remember there were a couple of hiccups in the process. Some things were fine but I think I had to open each of my Favorites files one by one + save them as VW2021 files in order to migrate them over which can't have been right... And I certainly don't want to mess up any of my current VW2021 settings in the process like happened to @hollister design Studio.
Thanks
Workspaces > migrating >
- checking if they still work
- checking if all new feature's Icons are there
- maybe do some rearrangements if your habits have changed
Settings > Omit (when I have the time)
- as VW settings aren't that many - Set again and get used to potential new Settings
- or when migrated, check for the new Settings
Workgroup Folder >
- create new 2022 Folder beside the previous
- copy and past an empty VW Folder Hierarchy, e.g. from User Folder into Workgroup Folder
- Batch Convert with subfolder option all VW 2021 into VW 2022
- Assign Workgroup Path in VW 2022 Settings.
Templates >
- are in my Workgroup Folder so will have been converted already
- create New Files from them
- check if they still work or update them with potential new features
- resave the Templates STAs
  • Like 4
Thanks @zoomer I don't use Workgroup Folders but is there an advantage in doing so? Is that where you store all your resources, as opposed to in Favorites in the User Folders?
Last time round, my settings + workspaces migrated over fine but my Favorites files + Templates files I had to copy over manually: I was expecting this to happen automatically as part of the Migration Manager process but I was wrong to think this right? You have to copy them manually then resave them in the new format? But do it in one fell swoop using Batch Convert? I have never used this before.
At any rate none of this should affect anything in 2021 should it? It didn't when I went from 2020 to 2021.
Yes
a)
I never used Favorites Folders (?)
These are not for me. I think I have no Favorites ...
And I think everything that I store in my Workgroup Folder - should at least be "Favorite".
(In fact there isn't that much in my Workgroup Folder. A few external Object Libraries,
My Templates, the old legacy "larger File" order of the Arrow RW Textures (Materials !)
b)
User Folder is accessible to a single user only.
Workgroup Folder is accessible for the whole team and can be centrally managed,
backup-ed and updated.
As I am basically a one man show,
the main reason may be Apple's SSD taxes.
User Folder is on you local SSD while Workgroup is on your Server, external Data or NAS drive.
I strictly separate System Disk and my Data.
Everything local or things that some Apps decide to save in "Documents" is Trash and volatile.
(If you ever lost your Windows Installation completely, directly after setting everything up for
weeks because of a Win Upgrade or lost large parts of you Linux installations because of
changing your GPU manufacturer, you may know what I mean)
And I can use my Workgroup Templates from any Mac or the PC !
With VWs complex, not always logical or legible Resource Folders Structure,
it would be very tedious to open and save to new VWX by hand.
(Subfolder option)
And it is comfortable to choose Source and Target Folders, to be sure that you
don't destroy something accidentally
That is why I use Batch Convert manually.
(Take care of your Source vs Target Folders. Or just copy and rename the previous WG Folder
and do Batch Convert only inside of this Duplicate)
Don't know what Migration Manager will do (?)
Just upgrading and overwriting the old Workgroup Folder ? Usually I want to keep those for
several VW legacy Versions.
BTW
I am not sure if just migrating VW Settings is (as) dangerous
(as it was e.g. in Modo App or Bricscad in the past)
But every Migration has a risk of causing instabilities. If I have the time I try to do it from scratch.
For me Workspace feels much more risky.
I one time had large problems and had to redo my migrated Workspace in earlier versions of VW,
thankfully everything worked pretty well with the last 3 Migrations.
And my custom Workspace is meanwhile so tedious to recreate that I went on taking the risk of
migration. I have to live now with losing my "direct numeric input" or "Render Long" setup in
Quick Settings and Top Bar - every few days though.
  • Like 3
@Andy Broomell + @zoomer thank you that's all really helpful. It's funny because I could swear there was no option in Migration Manager to migrate over my favourites when I did it last time. I knew it should have been there so even retraced my steps to look again + still couldn't see it the second time. But it's clear as day in your screenshot so that's very strange. But good to know it should be there for this time!
So Andy does the Migration Manager convert the Favorites + Templates files from VW2021 to VW2022 versions automatically as part of the process? And I'd only need to use Batch Convert if I wasn't using Migration Manager + I was moving stuff over + converting it to VW2022 manually which I think is what Zoomer's describing?
Thanks again. I will do the migration to 2022 in the morning... And will make a note of all this for next time as I'm bound to forget it all...
Yes.
Yes, I believe so.
Batch Convert pre-dates the Migration Manager; it simply takes a folder of VW files and migrates them. Migration Manager does that and more.
Not sure how one would go about migrating Workgroup folders, perhaps using the Migration Manager and just pointing it to the workgroup folder instead of the user folder?
Edited by Andy Broomell
I used both.
Just for more control or where I was unsure about reliability.
AFAIK
Migration Manager will just bring over everything from your VW 2021 User Folder to
the VW 2022 User Folder.
Not so for the Workgroup Folder I think, as it doesn't even Migrate (+update) the Workroup
Path in VW Settings. Which you have to redo manually.
So when all custom data and settings in User Folder, I think there is no need for starting
anything Batch Convert.
Beside that you want to migrate whole Projects with some complicated Folder Hierarchy.
I have about 1-5 VW Files and maybe 3-15 References per Project.
When I just open these too look if they work in the new VW Version, these are basically
already converted when I just hit save as ....
I never do migrate all (old) Projects to a new Version.
I do so on the fly if a Project gets back in use or because I want it for testing.
I mostly don't even upgrade my old Reference Files (as they are save in the File)
until I get new client files.
Edited by zoomer
Note the Migration Manager can include workspaces, xml files for settings, etc., while Batch Convert is just for VWX (and probably MCD) files.
At the same time, Batch Convert has additional options for "Convert in place" and archiving the previous version, so this is clearly geared more towards migrating project files rather than libraries.
  • Like 3
Yes Workspaces are no problem - as long as they don't corrupt while migration.
But I meant the Workgroup (or Office Standard) Folder.
I looked at your screenshots and did not find Workgroup mentioned here.
Edited by zoomer
There was previous advice, for preventing loss during migration, to store custom items and resources in a non default location and point vwx to that.  So I have a User Resources folder a vwx folder I created in Documents>vwx20xx titled Favorites.  This one has vwx files (and a readme) containing my custom stuff.  Each release, I convert to new, make aliases which go in the Application Support Favorites file.  Seems really cumbersome.  Might not even be safer than just placing such resources in the applications>vwx> App support>Library>favorites. ???
But more importantly
@zoomer& @Andy Broomell  Big thanks for responses on this thread!  I probably will have forgotten the details by next release, so, see ya in September.
-B
not sure.
I think that Favorites Folder in Application won't ever be overwritten (!?)
While most Application Resource file could with Updates and SPs.
On the other hand if you overwrite, or better prioritize such a file in App Folder
by a custom modified Version copy of that File in Workgroup or User Folder,
you would never realize or see when the App Resource gets updated by VW
at some point.
Isn't that basically the same as using a (separate) Workgroup Folder for each VW release (?)
2 hours ago, zoomer said:
...I never used Favorites Folders...
 I, oddly, have to use the favorites folder right now.
My 'user folder' isn't accessible from any of the "reduced size" Resource Managers that come with tools.
i.e. I can't get to my plants library from the plant tool unless I've favorited the plants library file.
I can get to  the premium and vectorworks libraries, but not to user and workgroup.
screen grab:
I must have things set up wrong.
I'm going to try and reproduce @Andy Broomell's file hierarchy example above!
Ahm,
Maybe I never tried if my User or Workspace Resources would ever show in standard PIO selection dialogs !?
I know that my Resources in File are available.
And I use Workgroup or Online Folders only to search for resources in Resource Manager.
And when I find something interesting I immediately "imported" these, directly into my file ......
Edited by zoomer
Don't match the hierarchy from the Migration Manager screenshot - it doesn't necessarily reflect the exact folder structure necessary for the RM to work properly.
And unfortunately I'm not familiar enough with how Plants work to be able to help out - I know they're their own beast.
Can you confirm whether Resource Selectors (which is the name for the mini-Resource Manager) for OTHER tools doesn't show your favorites files? For example, choosing Hatches, Linetypes, Door styles, Textures, etc. uses the same Resource Selector interface.
Note also Resource Selectors will only show files which contain the relevant resource type. So if none of your Favorite files contain actual Plant styles, for example, that could be a reason why the Favorites category appears empty.
