Accessory showing its own Legend
GTK
Assuming you are using VW 2012, and assuming you have attached the top hat using the Accessory Insertion tool, hit the "Edit Accessores" button in the OIP of the light the Top Hat is attached to.  In the Edit Accessory window, select the accessory, presumably the Top Hat, that is displaying the Label Legend.   Go to the "Use Legend" field in the Object Info Palette and select "None".
  • 2 weeks later...
In V2021, tried the method, and the accessory lable legend seems linked to the instrument, it sets the instrument's label legends as well. Wonder if that's a bug
