In the attached file, there are 8 sheet layer to be used as basic templates. All have simple rectangles for the border, and a Custom Title Block object with linked text. All of the title blocks are not activated, so the total # of active sheets should be zero.
If you activate a title block, the total sheet count goes up (as expected), but if you delete all the elements on a sheet (3), the sheet total does not change. Further, if you duplicate the blanked sheet, the sheet total goes up (like there is a ghost item on the page).
I can fix things by creating a new sheet layer, setting up the page set up, and then moving the elements from a defective sheet to the new sheet, and the deleting the newly vacatted defective sheet.
Questions:
Is there a way to delete the Ghost Activated invisible Title block border?
Is there an easier way to fix this than the workaround I described?
Ken White
Questions:
Thanks for your insights.
VW 2021 SP4 - Mac: Big Sur,
Templates.sta
5 answers to this question
