2022 - Wall Component Modeling
Tom Klaber
I was excited to try out the the wall component enhancements.  I could get neither the new wrapping functions to work - and when I tried to push pull components as shown in the video - the wall converted to a generic solid - same behavior as today.
Does this only work with special walls?
Is there a tutorial?
  • Like 2
1 hour ago, E|FA said:
On 10/20/2021 at 4:18 PM, Matt Panzer said:
Showing a gap between the GWB and the window jamb is arguably a higher level of detail than typically shown in floor plan and would be clarified in a separate detail drawing.
I'm definitely zooming in too far on a floor plan!
🤣  Certainly an easy thing to get caught up in.  Something you would never think about when hand drawing a floor plan.
Of course, we eventually want to cover as many cases as we can moving forward.
If this is working as designed, it is not an issue for me.  Thanks again.
No problem!
My first stab at the Wall Closure Settings. I'm trying to achieve this:
926640446_Screenshot2021-11-02at21_31_24.thumb.png.facfc74245ad2d3cf3edf445c99f2c7d.png
But the best I can come up with is this:
537076907_Screenshot2021-11-02at21_22_18.thumb.png.b6c57b1480ade6706a1d7aeaaf974401.png
Or this:
1808061173_Screenshot2021-11-02at21_23_03.thumb.png.319071bce17efc9bc28343f09f461184.png
I've tried every combination of settings I can think of.
@Matt Panzer is it only possible to wrap one component past the jamb? e.g.:
906874613_Screenshot2021-11-02at21_55_16.thumb.png.938f536747f190069748c2b3718bd6b2.png
Even when I do this the profile offset is in addition to the thickness of the component:
1378141789_Screenshot2021-11-02at21_59_28.thumb.png.ae72fabe6331cf03e2767d54b14107a4.png
Meaning the back of the component + the back of the jamb aren't aligning with each other (like they do in your video).
Probably not the best wall style to have chosen to demonstrate this with given it has a 2.5mm thick inner component but hopefully you get the idea. Could I post a file for you to look at yet again?
Thank you
6 hours ago, Matt Panzer said:
Ues. Please post the file and I’ll have a look.
Much appreciated. Here it is. Thank you
Wall closure test-ii.vwx
This is what you see when you open the file:
1374887377_Screenshot2021-11-03at06_19_17.thumb.png.e0b7d570cddb960095615dfaf23e6306.png
This is using the settings I would have expected to have given me the results I wanted (as shown in the first screenshot in the previous post + which I achieved by drawing it by hand). So be great to know why these settings instead give the results shown here. Why does only the first component extend to the jamb/insert + the subsequent two stop at the centre of core? In the previous post I had to add negative offsets to those components to have them extend the desired distance.
Also, does it make any difference whether you set the wall closure parameters in the wall or the door? These are just two different ways of accessing the same settings right? I mean the 'Wall Closure' dialog box for the door + the 'Wall Closure at Inserts' dialog for the wall.
Thanks!
There's an issue where the Interior Profile Offsets are being affected by the Exterior Profile Offsets.  I believe this is a known issue but I submitted another bug report with this file to make sure this is the same case.
The only way I can currently get the three interior components to look correct is to add Exterior Left and Right Profile Offsets of 26mm so they match the interior offsets.  Of course this makes the exterior side of the opening incorrect.
Right.  Basically, the Wall Style can have the settings and Wall instances can use the Wall Style Settings or they can choose to use their own.  Likewise, each insert can choose to use the wall settings or choose to use their own.
2 hours ago, Tom W. said:
OK thanks for checking. And for submitting the new bug. I appreciate it's probably not something you're in a position to say either way but hypothetically is this the kind of thing that might be dealt with in the next service pack? Or is it less straightforward than that?
Thank you
Unfortunately, I have no idea what's involved in fixing this.  However, it is a very high priority bug and we will do our bets to address it ASAP.
  • Like 2
2 hours ago, _James said:
@Matt Panzer I have to ask, what is in the 💥 menu in your Vectorworks!?
Ah yes.  That's my "blast" menu! 😉
Back in my PanzerCAD days, I had a "PCS" (PanzerCAD Services) menu that I kept my custom commands (or commands that are not part of the standard workspace).  Once we had Unicode support, I found the explosion icon character more compact and easy to find.  Plus it's kinda' fun.  🙂
BTW:  I also have a similar 💥 tool palette.
On 10/18/2021 at 7:06 AM, Matt Panzer said:
These are Window object Issues - I'll enter a bug report for these:
3.     Glass should inset into jamb and post by 1/2".
4.     Line thickness incorrect at and of glass.
5.     Wall line (from Draw Wall Lines setting) should be drawn below window graphics.
6.     In 3D, there’s a piece of white geometry protruding out of the window frame.
7.     Corner post looks correct in Top/Plan but the 3D geometry is not at the corner.
@Matt Panzer I didn't check on everything, but item 7 was not corrected in SP2.  Can you offer any updates or guidance?
Unfortunately, some of the corner window issues did not get fixed for 2022 SP2.
They are still a very high priority but I cannot give any definite time frame for when this will be fixed.
I will do what I can to bump this up even more.
Thanks.  From my perspective, getting performance improvements to more typical door/window/wall assemblies and killing the bug where everything goes crazy are much more important than the 3D visualization of corner widows.  Did we get any performance boosts or improvements/fixes to Walls & Windows in SP2?
Yes.  I've been seeing a 150% - 300% speed improvements in wall resets.  While this is a nice improvement, there's still room for more and we're continuing to investigate other possible improvements.
  • Like 4
On 9/16/2021 at 2:31 AM, Matt Panzer said:
You can get to the Plug-in Options via right-clicking on a plug-in or plug-in style (in the Resource Manager) and choosing Edit Plug-in Options.  This setting is off by default for now mainly due to some performance issues that we’re currently working to improve.  After this and some other possible tweaks are done, the “Use wall closure” option will likely be turned on by default.
@Matt Panzer is this still relevant information after SP2 update?
Shall we continue to control 'wall closure' instance by instance and not control it globally through using plugin options in RM...?
"Use wall closure" will remain off by default for Vectorworks 2022.
If you want closures for all instances of a style, I would control it "by style".  Otherwise, you may want it by instance.
Matt,  can you clarify which closure & wrapping settings for walls, doors, and windows are best left turned off for the time being in order to maximize performance.
In the Wall Style -> "Wall Closure at Inserts" settings, is it OK to leave the Wrap & Wrap to Insert checkmarks turned on, and then uncheck "Use Wall Closures" in the "Plug in Objects Style Options..." (right click on PIO in RM) for all my Windows or Doors (by style)?  I'd like to keep all the settings I've worked on, but disable the functionality for now so that I can reduce the lag & delays.
I've also unchecked Energos "Include in calculations" and "Create niche for space object" for all Windows/Walls/Doors (by style) in the hope that it will speed things up (and because I don't use Energos or Spaces).  Does this help, and are there any other settings I can change to help minimize lag?
Edited by E|FA
typo
Basically, the more complex the condition, the slower the performance.  Wrapped round profiles are the slowest with wrapped splay profile next.  If you're only using straight profiles, things should less affected.
Yes.  The closure settings won't affect anything unless "Use wall closure" is on for the insert.
I don't believe these settings will make any noticeable difference in performance.
  • Like 2
On 10/12/2021 at 9:27 PM, Matt Panzer said:
This is a little rough, but it should answer some of your questions:
I do not get the same results, I can not get the brick to move past the edge of the window with either Exterior Profile Offsets set to +2" or -2" or 0". And if I add a shim gap to start the same as you the brick does not return to the sheathing. I have to use an styled window so I can get the options. I am missing something
Can you attach a Vectorworks file with the just the wall and window in it?
I finally got it to work, it was the shim gap stopping it from looking correct in 2D plan, it was correct in 3D, but also noticed the shim gap in 3D even though it was unchecked in the window options, so then I put 0" in each option & it now is correct in 2D & 3D. Thanks so much for this video, I've been asking a way to add the brick mold in 3D for many years.
