bcd Posted September 18, 2021 Share Posted September 18, 2021 Ah , I get it now - Polygon Inner Boundary Fill doesn't work like you describe but simply draw a line across the face of a solid object, from edge to edge and you can pull / push either side of that line without needing to Fill. Much like Sketchup I'd say without the dots. Interestingly it only seems to be possible immediately after the line is drawn, you can't come back to it later and pick up one side of the face. Quote Link to comment
Andy Broomell Posted September 18, 2021 Share Posted September 18, 2021 1 hour ago, bcd said: Interestingly it only seems to be possible immediately after the line is drawn, you can't come back to it later and pick up one side of the face. You can do any time with the third mode of the Push/Pull tool (though some selecting is involved first). This mode actually predates the ability to do it immediately upon creation of the line. Quote Link to comment
MarcelP102 Posted September 18, 2021 Share Posted September 18, 2021 Wow that's great, thanks for testing 👍 Quote Link to comment
MarcelP102 Posted September 18, 2021 Share Posted September 18, 2021 I've managed to install the trail. Can’t seem to be able to paint only a part of a face by splitting it with a line. As you can see in the first image, the complete face light up with the selection tool. Of course I can use the third mode of the push-pull tool to push the face outward (second image). But this is not how buildings are made, most of time brick details are all in the same plane. Would be great if it works more like Sketchup, there a face gets split when drawing a line so you can paint both of the resulting faces individual. For now I will push pull outward 1mm. @bcd @Andy Broomell If you've got any tips I would like to know 🙂 Quote Link to comment
bcd Posted September 18, 2021 Share Posted September 18, 2021 Push a 1mm rectangular gap into the solid to separate the 2 faces. Quote Link to comment
Vectorworks, Inc Employee Popular Post sbarrett Posted September 22, 2021 Vectorworks, Inc Employee Popular Post Share Posted September 22, 2021 On 9/15/2021 at 1:51 PM, Tobias Kern said: Hi, thnx for the new VW 2022. I have to wait until end of october, before we, here in Germany get the new localized version. I have one question, maybe someone could investigate for me. In VW 2022 we got a enhanced wall tool with new wrappings. Got we also formulas (area, length, volume, material, separatable into horizontal an vertical wrappings because often the horizontal wrapping on the bottom inside/outside is made of different material) to calculate the data of the wrappings in tablesheets? I mean, are the wrappings only for a better visual representation, or is it more of a whole bim package? Greeting and thnx in advance! Tobi from Germany @Tobias Kern yes the volume and surface area of components are updated when they are wrapped. I have attached an image of the same wall in three different states and reported the component quantities in each. You can see that both the surface area and volume change not only when the window is inserted but also when the components are wrapped and splayed at the window. 5 Quote Link to comment
Tobias Kern Posted September 23, 2021 Share Posted September 23, 2021 (edited) @sbarrett HI Sarah, greetings and thxn for your investigation. Can i get an extra calculation only for the wrappings, separate to the wall-surface/volume? If i have to calculate here in Germany, i need to separate the surface/volume/length of the wrappings, because the cost are there much higher, because of its higher build complexity, as the rest of the wall. So i think, wrappings should have their own formulas! I think it is more useful to have also separate formulas for walls Wall-surface with and without wrappings Wall-volume with and without wrappings Hope the VW-Team, had this in mind, as they develop the wrapping functionality!? If not, please give us such formulas for VW 2023! Formulas for wrapping calculation: - length, width, area, volume, thickness of wrappings, - material of wrappings - separate formulas for top, left, right, bottom wrappings - location of the wrappings: inside or outside e.g. so that i can calculate: - bottom outside wrapping only length - top + left + right inside wrapping as area and so on … Calculations so flexible as possible! … and not only for wrappings, also for the rest of the BIM-tools Greetings Tobi Edited September 23, 2021 by Tobias Kern 1 Quote Link to comment
