Drapes and magic poles...
Hi VW peeps, does anyone know why pipe-and-drape still draws these drapes that magically penetrate the poles, both horizontally and vertically!?!?!? It's so annoying to get these silver uprights in your drape renders. Clients ask...'we aren't going to see the drape poles like this are we?' and as much as I feel like saying 'no dickhead', their question is perfectly acceptable because the visualisation shows the drape poles!!!
The vertical pipes and hardware can be classed. The hardware is likely wanted for plans and for inventory, not for renderings. Just turn them off, or use the option for similar in the OIP
One look might be desired in plans for the crew, another, without hardware might be wanted to show clients. The tool offers flexibility.
If you turn off the poles via Classes you end up with gaps where the poles were.
