Move objects - different settings for schematic and rack elevation DL?
I use the "Move" command a lot in my schematic DL. I have it set to the "Shift+arrow" hotkey, and set to my grid spacing of 1/8". Pretty much indispensable in this application.
However, in the rack elevation design layer, it really doesn't work...I can move an equipment item as expected, but once it's inside an equipment rack, the rack snapping (not sure if this is the correct term) over-rides any attempts to move it with the "Shift+arrow" hotkey.
Being able to use "Shift+up" or "Shift+down" to move items up or down 1.75"/1-ru in the rack elevation DL would be awesome.
Is this possible?
