Poot Posted September 9, 2021 Share Posted September 9, 2021 Hi everyone, I am wondering if there is a feature to add the expansion ratio into cut/fill calculations, for areas where the 'cuts' are blasted out from solid rock, and thus have an expansion ratio greater than 1:1 . In this case, blasting 1m³ of solid granite does not produce 1m³ of blasted rock, but more since that has now been blown to pieces with lots of gaps between them. Civil 3D has this function, but I was hoping there is also some similar feature in vectorworks? Thanks for any tips. Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted September 9, 2021 Vectorworks, Inc Employee Share Posted September 9, 2021 I would recommend that you do this in a worksheet - report on the cut and fill, and then use a formula to increase the bulking ratio as appropriate to the site. 2 Quote Link to comment
