eric.rktek Posted June 2, 2004 Share Posted June 2, 2004 I have been using the revised V11 stair tool, and really appreciate the ability to shift the stair break location dynamically. Is there anyway to have the break occur so that the lower half of the stair is hidden instead of the standard way of the upper half of the stair hidden above the break line? I want to hide the bottom part of a stair that should disappear below floor and walls of an upper plan without having to draw a polygon or some other masking technique. Thanks, Eric Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted June 2, 2004 Vectorworks, Inc Employee Share Posted June 2, 2004 On multi-flight stairs, only the upper flight can be controlled. Quote Link to comment
