pmosher Posted September 7, 2021 Share Posted September 7, 2021 I want to separate the interior and exterior walls in my file into two separate wall schedules. All the exterior walls have "Exterior" checked in the wall style (see attached screenshot) and that data, I think, is Pset_WallCommon - IsExternal=True. Can I set the database header to exclude or include all items with Pset_WallCommon - IsExternal=True? Quote Link to comment
shorter Posted September 8, 2021 Share Posted September 8, 2021 In the report, limit the selection by searching for a specific class or classes, and for all 'walls'. If you use Uniclass 2015 this is a bit frustrating since EF_25_10 will point to all 'Walls', so you will need to create an additional class for internal wall versus internal walls, e.g. A-EF_25_10-M_WallExternal A-EF_25_10-M_WallInternal Of course, if you have you own class standards, then the world is your proverbial bi-valve mollusc. 1 Quote Link to comment
Hans-Olav Posted September 8, 2021 Share Posted September 8, 2021 I usually limit to wall style, wallstyle starting with interior*, wallstyle starting with exterior*, 1 Quote Link to comment
pmosher Posted September 8, 2021 Author Share Posted September 8, 2021 I ended up adding a 0" thick material called EXTERIOR WALL to all exterior walls and edited the schedule criteria to only include walls where the EXTERIOR WALL material was present. It worked well and I didn't need to change any of my naming or class criteria. Quote Link to comment
shorter Posted September 8, 2021 Share Posted September 8, 2021 (edited) 12 hours ago, Hans-Olav said: I usually limit to wall style, wallstyle starting with interior*, wallstyle starting with exterior*, Tricky if you name walls in accordance with BS8541 or the forthcominig ISO. The bit that you need to search by is never at the start. Can you search by 'contains'? Edited September 8, 2021 by shorter Quote Link to comment
