unearthed Posted September 6, 2021 Share Posted September 6, 2021 (edited) I've received a dataset comprising 1799 stake objects (area is 3.75km² so they're reasonably sparse) and want to build a surface from them, when I try this in VW it says pick a valid object, it won't read the stake objects. I made a copy of the base dwg and exploded the blocks give me three objects - in bricscad: MTEXT Ellipse Hatch each object has the same height, all good so far https://imgur.com/uXVYpyp. After importing the above to VW I'm left with 3D Polygon - a line 24mm long with an accurate height x1091, one end of line is at ctr of Nurbs Curve object Text - with no height x1799 Nurbs curve - with same height as the 3D poly x1799 So the Nurbs looks like the best bet for an accurate representation, But I don't see any way of using it. Even a semi-accurate 3D poly based surface would do at a push tho', I see I can add 3D loci to the #D poly's but that doesn't help me much. I generally avoid making 3D surfaces in VW as have found process and product fruitless in the past but this time it looks like the only way forward. Has anyone else done this> Any tips welcome. Edited September 6, 2021 by unearthed typos Quote Link to comment
Tom W. Posted September 6, 2021 Share Posted September 6, 2021 Can you not just use the 3D Polygons as the source data for a Site Model? Or you could use the 'Replace with Symbol...' command to convert them into single 3D Loci first if you want each line to have one point rather than two + create the Site Model from the 3D Loci. 2 Quote Link to comment
unearthed Posted September 7, 2021 Author Share Posted September 7, 2021 On 9/6/2021 at 5:36 PM, Tom W. said: Can you not just use the 3D Polygons as the source data for a Site Model? Or you could use the 'Replace with Symbol...' command to convert them into single 3D Loci first if you want each line to have one point rather than two + create the Site Model from the 3D Loci. Thanks Tom W we had forgotten about the replace with symbol workflow, we're building a surface at the moment, thanks for getting us over the hump. 1 Quote Link to comment
