ekb Posted May 19, 2004 Share Posted May 19, 2004 I use the Issue Manager - works great. But, I have 2 questions: once an issue is issued, can it be de-issued? If I do not like my "issue number 4", can I "take it back" and issue a different "issue number 4"? I have not figured that one out. Secondly, I have a problem: names of drawings and drawing numbers in titleblocks on some sheets are doubled up, e.g. overlayed, e.g. the titleblock shows info from two different sheets superimposed, resulting in unreadable jumble. Can I fix it? Thank you. VW 10.5.1 on Windows Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted May 19, 2004 Vectorworks, Inc Employee Share Posted May 19, 2004 1. You can't "de-issue" at this time. 2. Which titleblock style? Can you send me a drawing with only the titleblock in it? (you'll need to let me know which fonts you use, also)... email to: randerson@nemetschek.net Quote Link to comment
jnr Posted May 20, 2004 Share Posted May 20, 2004 An ongoing issue since version 9, where you could edit revision #'s, dates, etc. http://techboard.nemetschek.net/ubb/ultimatebb.php?ubb=get_topic;f=16;t=001034 I find it very surprising that given the flexibility of the program, that this feature is cast in stone. Unfortunately, the Contractor could care less about software, but does care if you confuse them with multiple issues because you could not correct your mistake.... Quote Link to comment
