I am currently working on a small issue set that will not include all of our sheets. The only option there is currently in the issue data (in the title block manager) is to add the issue set to all the sheets or only 1. I do not have an option where I can just add an issue to my selection of sheets (like the revision data in the title block manager has).
My only way to make it happen right now is to apply my revision set to all the sheets and then delete one by one the issue on all the not used sheets. The contrary does not work because it will consider each issue I do for each page as a different one ( even if they have the same name)
Gregovitch
Thanks
9 answers to this question
