Ryan Russell Posted September 1, 2021 Share Posted September 1, 2021 All, I am trying desperately to reconstruct a survey in which no CAD file exists. The issue I am encountering is that the lot itself is a triangle, and the Northern and Southern property lines both have a slight radius that meet an actual radius on the Eastern side. Can anyone suggest a 'best practice' or straightforward approach to building the Northern and Southern property lines? * I have attached "Line_Example.pdf" for reference on the Surveyor drawing with the actual datum. Your assistance is greatly appreciated, as I am stumped on how best to move forward. - Ryan Russell Line_Example.pdf Quote Link to comment
Ryan Russell Posted September 1, 2021 Author Share Posted September 1, 2021 Also, as I am continuing to attempt to solve this, maybe the latest .pdf attachment can lend more information as to what I am trying to solve. Prpoerty_Line.pdf Quote Link to comment
michaelk Posted September 1, 2021 Share Posted September 1, 2021 I would definitely draw this as a poly line and then AEC > Create Objects From Shapes… > Property Line. If you draw it with north as straight up it will get all the meets and bounds correct. Quote Link to comment
Jeff Prince Posted September 2, 2021 Share Posted September 2, 2021 @Ryan Russellmaybe post the pdf of the entire survey so we can see what you’re dealing with? The property line tool is a bit sensitive with the data entry, but it looks like you have the necessary data to construct the curved property lines with the property line tool. Quote Link to comment
