Jayme McColgan Posted September 1, 2021 Share Posted September 1, 2021 lets say i have a 1'x1'x1' cube, i need to return the x,y,z of all the corners of the cube so i can format it to a .txt file to send that to another program. my goal is to achieve this for more detailed objects in the future. Quote Link to comment
JBenghiat Posted September 1, 2021 Share Posted September 1, 2021 This depends on the type of object, which is easier if you’re intentionally creating objects for export. The only object that gives you actual vertices is a mesh. If the objects are extrudes, you need to get the points off the planar base, the do the math to get the vertices in space. If it’s a generic solid, it can’t be done. Quote Link to comment
twk Posted September 1, 2021 Share Posted September 1, 2021 Here is a stripped out version from my custom python library for a geometry object. In this case the object must be a 3D type (Mesh, Extrude, 3DPoly, Nurbs, etc); And this is only for the 3D bounding box points. Josh is right, if its a mesh object, there are function calls to get the actual vertex points. import vs class GEOMETRY3D(): class POINT3D(): def __init__(self, x, y, z): self.x = x self.y = y self.z = z def __sub__(self, other): self.x -= other.x self.y -= other.y self.z -= other.z def __add__(self, other): self.x += other.x self.y += other.y self.z += other.z def mid_point_to_other_point(self, other_point): return def length_to_other_point(self, other_point): return def get_offset_pt(self, offsetX=0, offsetY=0, offsetZ=0): return GEOMETRY3D.POINT3D(self.x + offsetX, self.y + offsetY, self.z + offsetZ) def __init__(self, handle): self.handle = handle self.generate_bounding_box() def generate_bounding_box(self): self.top_center = GEOMETRY3D.POINT3D(self.center.x, self.center.y, self.center.z + (self.depth / 2)) self.bottom_center = GEOMETRY3D.POINT3D(self.center.x, self.center.y, self.center.z - (self.depth / 2)) self.top_back_left = self.top_center.get_offset_pt(-self.width / 2, self.height / 2) self.top_back_right = self.top_center.get_offset_pt(self.width / 2, self.height / 2) self.top_front_right = self.top_center.get_offset_pt(self.width / 2, -self.height / 2) self.top_front_left = self.top_center.get_offset_pt(-self.width / 2, -self.height / 2) self.bottom_back_left = self.bottom_center.get_offset_pt(-self.width / 2, self.height / 2) self.bottom_back_right = self.bottom_center.get_offset_pt(self.width / 2, self.height / 2) self.bottom_front_right = self.bottom_center.get_offset_pt(self.width / 2, -self.height / 2) self.bottom_front_left = self.bottom_center.get_offset_pt(-self.width / 2, -self.height / 2) @property def bounding_box_points(self): """ Top to bottom, Top Left Back to Top Front Left Counterclockwise --> then Bottom.. :return: """ return self.top_back_left, self.top_back_right, self.top_front_right, self.top_front_left, self.bottom_back_left, self.bottom_back_right, self.bottom_front_right, self.bottom_front_left @property def center(self): ptxy, z = vs.Get3DCntr(self.handle) return GEOMETRY3D.POINT3D(ptxy[0], ptxy[1], z) @property def height(self): return vs.Get3DInfo(self.handle)[0] @property def width(self): return vs.Get3DInfo(self.handle)[1] @property def depth(self): return vs.Get3DInfo(self.handle)[2] # obj3D = GEOMETRY3D(vs.FSActLayer()) # for x in obj3D.bounding_box_points: # vs.Locus3D(x.x, x.y, x.z) Quote Link to comment
Jayme McColgan Posted September 1, 2021 Author Share Posted September 1, 2021 55 minutes ago, JBenghiat said: This depends on the type of object, which is easier if you’re intentionally creating objects for export. The only object that gives you actual vertices is a mesh. If the objects are extrudes, you need to get the points off the planar base, the do the math to get the vertices in space. If it’s a generic solid, it can’t be done. so i've made some great progress with vs.ConvertTo3DPolys() and vs.GetPolyPt3D() to convert whatever selected symbols to polys. seems to be working great. ill post some source code once i work out a few kinks! Quote Link to comment
Jayme McColgan Posted September 1, 2021 Author Share Posted September 1, 2021 (edited) @twk i can't use bounding box because i need the actual geometry polys. i've worked it out. will post a sample after i work some kinks out. Edited September 1, 2021 by Jayme McColgan Quote Link to comment
