hollister design Studio Posted August 31, 2021 Share Posted August 31, 2021 I would like to select all the Umbellularia californica or Quercus agrifolia on a site. The Select Similar tool doesn't seem to have settings that can differentiate between Exiting trees. Is there a work around? Maybe through a worksheet? Quote Link to comment
Boh Posted August 31, 2021 Share Posted August 31, 2021 (edited) Have you played with the select similar tool settings? You can change these to suit the type of object' it's class, it's symbol name etc. It's works in a similar way to the custom selection tool in the tools palette. You just need a criteria that can single them out like symbol name, a record field, a class etc. Edited August 31, 2021 by Boh Quote Link to comment
Jeff Prince Posted August 31, 2021 Share Posted August 31, 2021 1 hour ago, Boh said: Have you played with the select similar tool settings? You can change these to suit the type of object' it's class, it's symbol name etc. It's works in a similar way to the custom selection tool in the tools palette. You just need a criteria that can single them out like symbol name, a record field, a class etc. I think you meant to say, try the Custom Selection tool from the Tools menu. That will do the trick. Example: 2 Quote Link to comment
hollister design Studio Posted August 31, 2021 Author Share Posted August 31, 2021 1 hour ago, jeff prince said: ... try the Custom Selection tool from the Tools menu... This is what I was looking for. 2 Quote Link to comment
