dhughes3 Posted August 30, 2021 Share Posted August 30, 2021 Hi, I'm trying to write a script which updates the texture mapping offsets using SetTexMapReal but am having a little trouble... After running the script the OIP correctly shows the new offsets but when you view the object the texture hasn't moved to reflect the new values. Any idea what I am doing wrong? Thanks, Duncan Quote Link to comment
Vectorworks, Inc Employee klinzey Posted August 30, 2021 Vectorworks, Inc Employee Share Posted August 30, 2021 Try resetting for forcing the object to redraw after you update the texture map. Quote Link to comment
dhughes3 Posted August 30, 2021 Author Share Posted August 30, 2021 21 minutes ago, klinzey said: Try resetting for forcing the object to redraw after you update the texture map. Thanks for the suggestion -Any tips on how? I tried the Redraw & RedrawAll commands but the texture still didnt update. Quote Link to comment
Vectorworks, Inc Employee klinzey Posted August 30, 2021 Vectorworks, Inc Employee Share Posted August 30, 2021 Try ResetOject() Quote Link to comment
dhughes3 Posted August 30, 2021 Author Share Posted August 30, 2021 13 minutes ago, klinzey said: Try ResetOject() Nope. didnt work. Maybe I'm doing something wrong in my code... Procedure SetMapping; Procedure SetOffset(h :HANDLE); BEGIN SetTexMapReal(h,3,1,300); ResetObject(h); End; Begin ForEachObject(SetOffset,(Sel=True)); End; Run (SetMapping); Quote Link to comment
