Edit the attributes of a complex linetype
Stéphane
Hello,
I have created my own complex linetype with some polygons. These polygons have a fill color and a pen color.
Then, when I use my new complex linetype in the design space with Polyline for instance, I can only change the pen color and the line thickness but not the fill color of the polygons that I used to create my custom complex linetype. This means I need to duplicate my linetype for each new fill color I need ? Is that the normal behavior ? Is there a trick to be able to change the fill color as well ?
Creating my complex linetype :
446822921_Capturedcran2021-08-2709_35_09.thumb.png.311144ad5142d27d3a92e1a5b3f6f8cb.png
Drawing a Polyline with my new complex linetype (as you can see I was able to edit pen color but not fill color as I would like to) :
496571724_Capturedcran2021-08-2709_35_48.thumb.png.0a21727342c697da759cef8867986d06.png
5 answers to this question
In my opinion, it shouldn't work like that. A complex linetype is a linetype and it should work as a basic linetype. The pen attribute controls the color of a basic linetype. The pen attributes should also control the color of a complex linetype (fill+pen). I cannot see a good reason why it shouldn't work like that. You never use more than one color anyway for a complex linetype.
As a workaround I filled my complex linetype with lines... Not sure if it's a brillant idea tho 🙂
Step 1 : Add lines in your custom complex linetype.
1994678562_Capturedcran2021-08-2717_12_36.thumb.png.10f2fb00205768c60ee78c5c9c95737d.png
Step 2 : Make it thicker
1659498601_Capturedcran2021-08-2717_14_06.thumb.png.eae469367d971facba5267e5c911e7a3.png
Step 3 : Profit...
1360410934_Capturedcran2021-08-2717_14_31.png.b3f13b52e010f7c2a20535acac7aaaed.png      463124849_Capturedcran2021-08-2717_14_40.png.20e8ea323eb58bad7991d9ab254c15ca.png
It is quite possible that you don't use more than one color for a Linotype, but I will pretty much guarantee you that there are people who rely on the ability to have multiple colors in their complex linotypes to get the drawings they want.
I have learned to never assume that everyone uses VW the way I do.
Posted (edited)
You are right, it is good to have several ways of using a tool. So you would say that complex linetypes work as they should ? Would you confirm that for each new fill color, you need to duplicate the complex linetype ? By the way, it also means you cannot override its fill attributes in a viewport.
Edited by Stéphane
