3d pio insert in 3d space
Another feature that would be welcomed is inserting 3d parametric objects in 3d space. Currently inserting the object will automagically throw you back into 2d plan view. Since I'm often inserting the 3d object in some plane other than plan, I'd like to avoid inserting in plan, perform Rotate3d, switch to back to the appropriate view, then try to find the center of the object (like the center of the bottom of a bolt head) without having a locus to grab, and then drag it back over to the hole.
If the 3d object snapping was more robust (see earlier post), this would not be as much of a hassle...
