Mat Caird Posted August 24, 2021 Share Posted August 24, 2021 Hi All - I need some help with Worksheets and Record Formats please; I have a file with 2 design layers; "Model", and "Parts List". I have built the model using custom symbols, all of which have a record attached. On the design layer "Parts List" I have a worksheet to list all the part names (a record attached to each symbol), and also a single instance of each symbol. When I use the =COUNT function in the worksheet, it sums all the symbols with the same part name in the drawing, ie all on the Model layer, plus the additional symbol on the Parts List layer. So I need a worksheet calculation =COUNT-1 but this doesn't work for a database worksheet. Or I need to include only the instances on the Model layer in the =COUNT, but I can't get this to work either. Or I need a new spreadsheet worksheet that takes the data from the =COUNT column of the database worksheet, and subtracts 1, but I can't get this to work. I could workaround by deleting the extra symbols on the Parts List layer, but I want to avoid this if possible. Or maybe a design layer reference to a new file, etc, etc. There are workarounds I could try. But =COUNT-1 is my preferred approach. Any ideas please? PFA. Thanks in advance, Mat. Quote Link to comment
bcd Posted August 24, 2021 Share Posted August 24, 2021 (edited) You just need to add another Criterion in your Database Critera Layer=Model (L="Model') Edited August 24, 2021 by bcd 1 Quote Link to comment
Pat Stanford Posted August 24, 2021 Share Posted August 24, 2021 Or in case you end up with more than one Model layer in the future Layer Is Not "Parts List" Quote Link to comment
Mat Caird Posted August 24, 2021 Author Share Posted August 24, 2021 Thank you guys. Where / how do I insert the criteria? I tried this in the cell where previously =COUNT was located; =COUNT((L<>'Parts')) What is the correct syntax please? Quote Link to comment
bcd Posted August 24, 2021 Share Posted August 24, 2021 Click on the 2 row on the left - Edit Criteria and select the relevant Criteria Quote Link to comment
Mat Caird Posted August 25, 2021 Author Share Posted August 25, 2021 Thank you BDC, and others, yes that worked. 1 Quote Link to comment
