buz Posted April 18, 2004 Share Posted April 18, 2004 This is the second time now that this dialog box (window) ha shown up and I'm not sure why. It says - "All Serial Numbers In Use" and then 'A VWs license can only be used by one machine at a time. All given serial numbers are in use by other users on the network.' I am the only user on the network and my options are to quit / edit numbers / retry numbers. Quitting and I will loose some work, retrying numbers doesn't satisfy the problem and there's no sense in editting the numbers as it is the only one I have (For VWA and RW). Any ideas how I can convince VWs that I am the only user? Quote Link to comment
buz Posted April 18, 2004 Author Share Posted April 18, 2004 Robert When I retry, the same window just comes back up - suggesting I either 'Quit' or 'Edit' the code. I'm the only user of my computer and our small network is primarily for printer sharing, the only other computer connected is my wifes and she has no interest in VW. The 'warning' dialog pops up very randomly. It allows me to save my work and then I relaunch VW and continue till it decides there's another 'ghost' user somewhere. Quote Link to comment
Guest Posted April 19, 2004 Share Posted April 19, 2004 Are all the users updated to VW 10.5.1, or do you have some using 10.5.1, some on 10.5.0 and some on and earlier version of 10 ? If so, that is probably the culprit. You should have everyone update to VW 10.5.1 and then restart the computers to resolve the problem. Quote Link to comment
buz Posted April 19, 2004 Author Share Posted April 19, 2004 Katie I am the ONLY user. I may have solved the problem. Last week I had to do an archive and install of my system which preserves the old system folder and creates a new one. I removed the VW prefs from the 'old' system folder (actually copied them to the new folder) - but now there is only one copy of VW prefs on the computer .... could have been the problem. I'll let you know if the problem persists. Buz Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted April 19, 2004 Vectorworks, Inc Employee Share Posted April 19, 2004 What happens when you Retry? Quote Link to comment
buz Posted April 24, 2004 Author Share Posted April 24, 2004 Katie/Robert The problem persists! I had recently did an archive and install without saving user and network prefs. Consequently I had to re-enter my registration number. I thought perhaps I had the problem solved by deleting my VWA prefs from the 'Previous System' folder, which is automatically created by the system install I did. When the window pops up and I retry 3 times ... VW has a preset limit of '3' tries and then quits automatically. I'm really stumped here not to mention a bit aggravated by this pesky issue. Often times, I will be in the middle of some work and stop for lunch or whatever and come back to find the system suspecting there's more than one user at work and has the 'pop up window' staring at me looking for other registration numbers. Any other thoughts? Thank you Quote Link to comment
buz Posted April 24, 2004 Author Share Posted April 24, 2004 Did a 'Find' search of my HD for VW and found another .plist pref for VW in the previous system folder ... so my hopes are up again. As before - I'll let you know. Buz Quote Link to comment
buz Posted April 26, 2004 Author Share Posted April 26, 2004 Nope - still popping up and sometimes 'retry numbers' works and others it doesn't. I'm really baffled now. Any other ideas? Quote Link to comment
Guest Posted April 26, 2004 Share Posted April 26, 2004 Have you tried repairing disk permissions? You might also want to update to 10.2.8. Quote Link to comment
buz Posted May 13, 2004 Author Share Posted May 13, 2004 just testing - thank you Quote Link to comment
rcarch Posted May 13, 2004 Share Posted May 13, 2004 buz- are you running on an airport network? i have experienced the same thing we have two machines w/ 2 licenses and that will pop up every once in a while. i usually rebooted my computer until i figured out the airport was causing it. Quote Link to comment
buz Posted May 15, 2004 Author Share Posted May 15, 2004 No - noy using airport - direct ethernet conections to LAN. The problem seems to have quit ... problem with that is that I don't know why it quit (for future reference). Thanks for all your suggestions and help. Quote Link to comment
