Rishie Posted August 23, 2021 Share Posted August 23, 2021 Hi, When I was relaying the floor plan I removed a few internal walls that were connected with the external wall's core components. I can find a glitch in the external walls where the internal cladding does not connect again while removing the internal wall. I tried to replace the external wall style with the same style to check if this refreshes the wall again but with no luck. Can anyone here help me to connect the internal wall cladding? FYI, I also tried with the component joint again with no luck. Thank you, Rishie 🙂 Quote Link to comment
Tom W. Posted August 23, 2021 Share Posted August 23, 2021 Does 'Remove Wall Breaks' work? 1 Quote Link to comment
Rishie Posted August 24, 2021 Author Share Posted August 24, 2021 Wow! Yes it's working! I'm using this tool for the first time. Thank you so much Tom :) 1 Quote Link to comment
