Suspend Snapping is now not working in 2021
Ramon PG
I use the tilde key for the arrow tool and had and set the X key for "Suspend Snapping", but even when set it does not work. Any suggestions are appreciated... My setup used to work fine in 2017.
Update: retested it using the tilde key and, still... doesn't work.
Edited by Ramon PG
I testet it with VW 2021 SP4 on M1 Mac with Monterey,
It works fine for me.
For me "tilde" key means ">" key on my QWERTZ keyboard.
(But it is at the same location on keyboard as US tilde)
You may try a different "default" Workspace.
If that would work, it may be a problem with your Workspace's
short cut assignments or a corrupt Workspace.
I'll check that, thanks. Now I recall that it has happened before and this time actually not all the settings transported from 2017 to 2021.
Seems I have to recreate the whole command structure, even the stock ones like copy and paste!!
Update: recreating the Basic Tools palette is giving me an incredible hard time. The items don't want to move and behave!! Really buggy!! Wow.
Edited by Ramon PG
Well, I was pretty successfully migrating my Workspaces, since VW 2017 or so,
by each years upgrade. But migration over 4 years may be more risky.
Maybe it is easier to create the Workspace from scratch from a Default VW
Workspace vs trying to repair your custom Workspace.
(Well, for me, there were so many customizations in Workspace that I gave up
my planned Workspace from scratch for VW 2021. But so far my only problems
seem to be constantly losing settings of Top Palette entries)
